What is this piece called that is missing?
Old Apr 7, 2009 | 05:27 PM
Lunchb0x8675309's Avatar
Car: 1988 Iroc-Z28
There is a plate missing on my engine and I don't know what it is technically called. It looks like it bolts into the intake and cover the distributor cap area?
Here is the best picture I can show you, straight back of the intake towards the distributor cap
http://memimage.cardomain.com/ride_i...0019_large.jpg
Where can I buy a replacement one?
Old Apr 7, 2009 | 06:22 PM
deus402's Avatar
Transmission: 4l60e (700r4)
Axle/Gears: 4.10
Re: What is this piece called that is missing?
GM P/N 10108425 Aluminum Plenum Extension $ 19.50
GM P/N 14082425 Screws (for plenum extension) $0.42 x 3
thats the part number for the aluminum one off of a vette, the f-bodies had plastic ones, not sure of the part number, or why you would get it instead of the aluminum. you should be able to pick them up at your local gm dealership. also, those prices are pretty old, so they may not be correct anymore.
Old Apr 7, 2009 | 06:25 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
deus is correct. The cover's only function is to prevent water from dripping off the hood and onto the distributor cap. I don't have one and have never had a problem, however it's pretty dry up here in Calgary.
-Z
Old Apr 7, 2009 | 06:51 PM
Car: 1988 Iroc-Z28
Thanks for the response, yeah I didn't know they plastic ones so I will opt for the metal.
Old Apr 7, 2009 | 07:49 PM
thegooseman's Avatar
Car: 1992 RS
-Z
Really? I thought it was just to make it look cleaner, but that makes sense.
Old Apr 7, 2009 | 08:06 PM
gunner53227's Avatar
Car: 86 TRANS AM
Transmission: 700 R4
Axle/Gears: 10 bolt/3.73
They also sell it on modern day muscle. Plastic or aluminum.
http://www.moderndaymuscle.com/underhood4?b=1
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
