NO SPARK! AFTER MOTOR SWAP??? HELP!!
Old Apr 9, 2009 | 08:23 PM
stock's Avatar
Car: 91 gta and chevy powered toyota
Engine: 5.7 in both of them
Transmission: 700r4 raptor
I DID A SWAP ON A 91 FIREBIRD WITH A V6 TO A V8 HAD ALL THE PARTS FROM A DONOR CAR ,AND THAT WAS A 91 GTA SLP CAR....I CHANGED EVERYTHING ..THE HARNESS,ECM FUEL PUMP BRAKE LINES,ALL I THOUGHT I HAD TO DO YET WAS CHANGE THE FRONT SPRINGS,,SO I CHECKED ALL THE FLUIDS FRESH OIL CHANGE,FRESH PLUGS,MSD BILLET DISTRIBUTOR,SO TODAY WAS THE DAY IT WAS SUPPOSED TO TURN OVER... WELL IT DOES NOT HAVE ANY SPARK! I HAVE POWER GOING TO THE PINK WIRE THAT GOES TO THE COIL,I TRIED A NEW COIL THAT DID NOT WORK,NEW CAP ,,THAT DIDN'T WORK EITHER! NEW MODULE ,NO GO .
PULLED THE COIL WIRE OF THE DISTRIBUTOR TURN THE KEY AND NO SPARK..EVERYTHINGS SEEM TO WORK THE WAY THE DONOR CAR WORKED ACCEPT THE SPARK! AND THE DONOR CAR RAN WELL..THE ONLY THING I LEFT OUT IS THE OIL PRESSURE SENDING UNIT IT NOT HOOKED UP IT BROKE DURRING THE INSTALATION..COULD THAT SENSER BE PREVENTING THE CAR FROM HAVING NO SPARK? THE CAR HAS BEEN SITTING A COUPLE OF YEARS ALSO... THANK YOU IN ADVANCE TO THE MEMBERS THAT WILL HELP..
Old Apr 9, 2009 | 08:45 PM
BloodyBlueBird's Avatar
Car: 86' Firebird
Engine: 350 c.i. swap
Transmission: G-Force T5
Re: NO SPARK
I have the same damn problem ... I hope you have better luck than I do.
Old Apr 9, 2009 | 08:51 PM
stock's Avatar
Re: NO SPARK
I SAW YOUR THREAD BLUEBIRD....I TRIED EVERYTHING! I KNOW THIS IS THE RIGHT PLACE TO GET THE HELP...
Old Apr 10, 2009 | 02:34 PM
stock's Avatar
Re: NO SPARK
I keep watching your thread..maybe we have the same prob..
still pullin hair out over here....
Old Apr 10, 2009 | 02:41 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: NO SPARK! AFTER MOTOR SWAP??? HELP!!
Actually yes the oil pressure switch will cause problems. Now i dont believe it has anything to do with the ignition end of things but it will cut power to the fuel pump.
Old Apr 10, 2009 | 02:43 PM
Or do you mean the oil pressure sender to the guage?
Old Apr 10, 2009 | 03:00 PM
stock's Avatar
The plastic one ..That is on the left hand side of the engine,closest to the oil filter...I have one pluged in but nt screwed into the engine...
Thanks for the reply
Old Apr 10, 2009 | 03:54 PM
Car: 86' Firebird
Re: NO SPARK
Yeah maybe, Tonight when I get my buddies voltmeter back I'm going to start all over and check everything again. maybe I missed something. Mine could be the pickup coil, but since yours is the billet style that wouldn't be the case for you.
If you have an ignition box that could have gone out. I have heard people say that they had it go out within 2 weeks that they got it.
Old Apr 10, 2009 | 04:09 PM
Alright well first lets look at the ignition system because reguardless it should have spark. Now you mention your useing the MSD set up im not familiar with it but does it use the 4 pin EST connector? or is it more a self contained vacuum advanced unit?
Old Apr 10, 2009 | 05:42 PM
stock's Avatar
GOT IT !!!! IT WAS THE OIL PRESSURE SENDING UNIT ,,,CANT BELIEVE IT!
DAMM THING KICKED RIGHT OVER,THANKS TO A BUDDY THAT CAME OVER AND BROUGHT ME A NEW SENDING UNIT,,STILL CANT BELIEVE THAT LITTLE SENSER WOULD DISABLE THE SPARK!! WOW...WHAT A WIEGHT OFF,,THANKS GUYS
Old Apr 10, 2009 | 08:52 PM
Car: 86' Firebird
Hey at least one of us got ours to work. I used the voltmeter on mine and found everything was perfect. (measured in OHMS) so I am still confused
But that's cool that you got yours to work.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
cstrobel65
Aug 15, 2015 10:19 AM
st.evel07
Aug 13, 2015 06:15 PM
