cam question
Old Apr 14, 2009 | 08:47 AM
jg87iroc's Avatar
Engine: 355
cam question
well im getting along with with tpi to 355 carb swap. the engine i picked up is a rebuilt 350 with 40k on it. my queston is with the cam. i want to go with the thumper series. i was thinking the smallest one would work best with stock heads. can i safely rev this engine to 5800 rpm. if i had a high volume pan and pump would this allow me to safely rev it higher?
Old Apr 14, 2009 | 09:07 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: cam question
revving to 5800 is not too high....but the heads and exhaust might not allow it to rev that high....call comp cams and talk to a rep. to work out the detail with you cam would be the best idea.....what really kills you is the 2.73 gears you have...I would change those, and then change the cam after to match.....what is the part number of cam your looking at??
Old Apr 15, 2009 | 01:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The market for the Thumper series is people who are more after a certain idle sound than performance. Does that tell you anything? Or, does that describe you?
Stock heads isn't so much the issue as is valve springs. What are you planning on using?
BTW, what "stock" 350 heads do you actually have?
Old Apr 17, 2009 | 01:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: cam question
3.73:1 gears, then cam. If it's just an 8.5:1, smog-headed 350, you'll like it better with COMP's DualEnergy 275 cam.
Old Apr 20, 2009 | 09:04 AM
jg87iroc's Avatar
Engine: 355
Re: cam question
no i dont just want a cool sounding car i want power, the i like the tight lsa of the thumpers and that i dont have to rev it super high to make good power. i called comp and got the thumper cam along with there matching valvesprings and lifter. im going to go with 3.73s and a hughes 2500 stall converter. ill be taking the heads off tomorow to debure them and do a 3 angle valve job so ill get the numbers off them then, oh the engine is from '69
Old Apr 20, 2009 | 09:30 AM
jg87iroc's Avatar
Engine: 355
Re: cam question
ok well i was looking at comps thumpr brocheur and they could not make 400hp with 180cc rhs heads and the big thumper cam........i just filled out my return form, you guys win lol
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
