Cam bearing selection.
Old Apr 18, 2009 | 03:00 AM
thunder-lips's Avatar
Car: 1989 Formula 350
Engine: building a 383 as of Feb. 09
Transmission: 700 R4, B&M shift kit
Axle/Gears: 3.23?
I am building a 383 and in the process of buying parts for it. I don't know what cam bearings to get. Cam is a hyd flat tappet.
http://store.summitracing.com/egnsea...splayPrice%7C1
I am pretty sure those are the right options to choose from. What would be the best choice?
Old Apr 18, 2009 | 11:58 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Cam bearing selection.
Unless you have your own cam bearing installation tool, just let the local machine shop install whatever bearings they have. Every automotive machine shop in America keeps a few sets of SBC cam bearings on their shelves.
Old Apr 18, 2009 | 03:42 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
I just had them installed when I had the block in for work. I supplied them with King Alecular Silicone to install- too easy to mess it up if you haven't done it before, and you have to have a cam bearing install tool.
Old Apr 18, 2009 | 03:50 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I've been on both sides of the fence. Amateur like you, and now 9 years as a professional automotive machinist. I've met a few dumba$$ machine shop owners who couldn't install trick parts to save their lives, but 99.9% of us can do anything you can do better than you can do it.
You do need to use a dedicated tool, and you don't need King, Clevite works just fine, as does SpeedPro.
Old Apr 18, 2009 | 04:08 PM
Axle/Gears: 3.23?
Thanks for the advice on cam bearing install everyone. But I had no intention of doing it myself. Was just going to supply the bearings for the shop to install when the block work will be done.
Old Apr 19, 2009 | 10:07 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Good call. I think my shop only charged about $30 to install the bearings. By the time you get done with baking/tanking, boring, honing, etc, it's just water under the bridge.
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
anesthes
Aug 26, 2015 01:37 PM
