Will these 1.6 rr work for me?
Old Apr 20, 2009 | 07:02 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Hey guys i have a 96 impala ss LT1 with iron heads then im putting a .540 in lift cam. So will these work or no?
http://detroit.craigslist.org/pts/1119906460.html
thanks
kevin
Old Apr 21, 2009 | 12:28 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: Will these 1.6 rr work for me?
Without getting too lengthy... you may need to change your pushrods so your valvetrain geometry is correct. I can't recall if the LT1 uses 1.6 ratio stock or not. Do you have valve springs to match the new cam?
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Fronzizzle
Aug 17, 2015 02:52 PM
happyhapka
Aug 15, 2015 04:42 PM
