280XFI - Anyone use this cam?
Old Apr 26, 2009 | 04:37 PM
Demon355's Avatar
Question is mainly about valve springs but I guess it would be nice to know others have used this cam with good sucess. But getting back to the question.
My 383 runs this cam with a set of World Sportsman II heads. My current valve springs are unknown but when these heads were on my buddies old 355; his cam was the XE284. Being that it was in the .520 range the springs might have worked fine and he mentioned that I'd be alright with the 280XFI and those same springs. Is this true? We both don't know what they are rated for so it's hard to say. What do you guys run or suggest me running instead? Thanks!
Old Apr 26, 2009 | 04:42 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 280XFI - Anyone use this cam?
first, which block and rockers do you have? flat or roller, and 1.5:1 or 1.6:1 because the roller with 1.6s is .576" lift. This would certainly call for a set of 26918 beehives.
Old Apr 26, 2009 | 04:44 PM
Demon355's Avatar
I have the roller version, sorry for not mentioning. 26918 eh? I was thinking of getting some beehives (had them on my old 357). These would work well? The cam is pretty aggresive with the ramps so I would need a beefy spring.
Old Apr 26, 2009 | 04:46 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The 26918s are about the only thing that'll take that much lift without killing the roller lifters with too much open pressure.
Old Apr 26, 2009 | 04:47 PM
Demon355's Avatar
Sounds good to me. Thanks man!
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
