head gaskets?
Old May 2, 2009 | 10:46 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
head gaskets?
so in one of my other posts someone mentioned not to use steel headgaskets because if the block or head is not truely flat it will leak. does anyone hve any other input on this matter? thanks.!
Old May 4, 2009 | 11:52 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: head gaskets?
It's okay to run them on used blocks if they pass the straightedge test and have no dings or nicks you can see or feel. You should always have any heads, new or used, resurfaced before installing them. Also, the pistons must be at least 0.020" in the hole at top dead center. Following the above guidelines, I've never had nor heard of any trouble with FelPro steelshims.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
