just wondering but....
Old May 10, 2009 | 12:15 AM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
If I were to jack up my rear end and spine the tires, will that rotate my engine? I’ve tried pulling the spark plugs (to have less compression) and pulled on the belt before, but that’s a pain… and my car has been sitting so long (almost assembled) I just feel the need to rotate it every once in a while to make sure the engine doesn’t lock up…
Old May 10, 2009 | 12:48 AM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: just wondering but....
The way I do it is leave the car on the ground, transmission in 5th, and push it. To jack it up and turn it, you'd need to leave on tire on the ground, or turn both. Of course, none of this will work if you have an automatic trans.
Old May 10, 2009 | 01:03 AM
burn0ut305's Avatar
Car: z28
Ok so it will work… but y wouldn’t it work for an auto, cant you just put it in neutral? I’m not trying to start the engine, just trying to rotate the internals of the motor (so noting gets locked up)…
Old May 10, 2009 | 01:18 AM
drtask's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V6
with neutral there's no resistance on the motor. no turning. that's why its easy to push the car there's no resistance in neutral.
Old May 10, 2009 | 08:56 AM
burn0ut305's Avatar
Car: z28
ok so the anser to my question would b no then...
Old May 10, 2009 | 09:02 AM
stevenabenton's Avatar
just turning an engine does not help unless you get OIL PRESSURE and fresh oil to the parts. Thats what you are after!!!
Old May 10, 2009 | 09:13 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
buy a oil priming tool and use a drill and run some oil thru the motor that way. y not just start it and let it run till it warms up then goose it a lil then just shut it off. (i just like to goose it to hear the exhaust) i do this during the winter to keep my battery charged up and keep the cylinders from rusting.
Old May 24, 2009 | 07:02 PM
burn0ut305's Avatar
Car: z28
lol thats hard to do when half ur motor is apart... but not to worrie everything is get put back togeather by a tec now cuz im in texas for school..
92projectcamaro
Dec 8, 2015 12:25 AM
Bradsaundry
Oct 7, 2015 04:35 PM
loud91rs
Oct 5, 2015 10:05 PM
