cam swap need some advice
Old May 10, 2009 | 11:45 AM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i put this in this section because it is a drag car that sees occasional street time... mods feel free to move it
i have a 1pc rearmain 350 factory roller motor but currently it has a flat tappet xe274 cam. im worried my cam is goin flat and i wanna get it out of there asap before anything else gets ruined.
i def wanna go roller and my heads are already done up with springs that are good to .550lift
http://store.summitracing.com/partde...rsview=sku&Ns=
this cam seems like a good choice but says it designed for trickflow heads... i dont see why it wouldnt work with my vortecs
Old May 10, 2009 | 07:04 PM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: cam swap need some advice
You need some compression for that cam, and it will be a PITA on the street. If you have the compression, and the exhaust side cleaned up a little on the heads it should work out great. The vortec heads seem to like a higher exhaust duration.
Old May 10, 2009 | 10:21 PM
gtpro700's Avatar
Car: 87 Firebird Formula
Engine: AFR headed SBC
Transmission: TKO 600
Axle/Gears: 9" Moser with 4.11's
Seems like a decent cam. I dont think your goign to need that much CR to run that cam. PITA on the street???? People always say that but I dont really understand the problem. I dunno streetablity is a VERY subjective word to me lol
Old May 11, 2009 | 12:07 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
way too much lift.
Old May 12, 2009 | 09:01 PM
MaNiAk86's Avatar
Car: 1983 trans am
my springs are good to .550 lift so i think .539 should be ok. what confuses me is my current cam @.050 is 236/242 and advertised 286/292. but this trick flow cam at .050 is 230/234 and advertised is 292/296
Old May 12, 2009 | 10:00 PM
gtpro700's Avatar
Yes your springs might handle the lift BUT your heads probably wont flow that well at those lift numbers. I personally dont know a lot about flow numbers on vortec heads but im pretty sure they dont flow well over .450-500 lift. Also depends if you have done any work to them as well.
As for the duration numbers I think you should just compare duration at .050 because that is the benchmark for all manufacturers and the Adertised is usually a selling trick, I think, if im wrong someone chime in. I think of it as a speaker with RMS power and Peak power. The RMS power is what counts because the peak power is essentially a useless number.
So if your losing duration and gaining lift that wont net you any power because you heads wont flow up high anyway, then the cam swap might not be a good one. I would look around for proven cams with vortec setups that make good power and go that route.
Old May 13, 2009 | 06:47 PM
MaNiAk86's Avatar
Car: 1983 trans am
ya def not a good cam choice
heres a better choice i think
http://store.summitracing.com/partde...8&autoview=sku
Old May 13, 2009 | 09:08 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Frist off, cool looking car. I think the trick flow cam would be better. It has a 110 LSA and the COMP Cams 12-601-8 has a 107 LSA that will cause the engine to have a rougher idle and more overlap.
Old May 13, 2009 | 09:51 PM
MaNiAk86's Avatar
Car: 1983 trans am
first off thanks and second i have a 2800 stall and love the sound of a rough idle so i'm lookin forward to the 107lca it will also tighten up my powerband so i dont have to rev it out as far... stock bottom end you know...
xkingcodex
Feb 12, 2020 07:43 PM
Cameeeero
Sep 18, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
