How damaging is water to TPI
Old May 10, 2009 | 06:51 PM
Synful's Avatar
Hypothetically speaking, let's assume you take a hose and spray down the engine compartment of my 87 305 TPI, just all over the place until its soaking.
What kind of things could go wrong if I tried to start it, assuming everything is in working order and the wiring is the way it ought to be.
Also, same question but if you just point the hose down, right above the plenum, and spray.
Old May 10, 2009 | 06:58 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: How damaging is water to TPI
they steam clean them and dont do any damage. cover anything that looks like if it gets wet - like the distributor - will have problems in starting or running - and have a good time.
just dont put the hose directly on it with the intent of seeing how much water you force into it.
Old May 10, 2009 | 08:03 PM
86sdubzzT/A's Avatar
Car: 1986 T/A
Axle/Gears: Stock
Hypothetically speaking....what the heck did you do?
Soaking very old wires/connectors cant be a great idea imo
Old May 10, 2009 | 08:10 PM
Synful's Avatar
Hypothetically Speaking... what would happen if I drove the front end of my car into a 3' children's outdoor above ground pool on accident. What kind of things could the water do up front there...
Old May 10, 2009 | 08:55 PM
Car: 1986 T/A
Axle/Gears: Stock
No Way!! Im not sure if you're serious. If so, Im sure it stalled out. Did you already try and start it? I would let it dry for a while personally.
Sorry for making jokes but I hope there was no kids in the pool at the time.
Old May 10, 2009 | 09:08 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i hope thats a joke
because if it happend it would be like soo funny, but would think that would do some damage to the looks of the car also, 3 feet of water and prob 15 foot around, if my math is correct thats like almost 2,600 gallons of water and thats 21,000 LBS plus, hitting that would do some damage and the water on the motor would be the least of your concern
now if your just spraying it down to clean it you should have no problems if you do like people above suggested
Old May 10, 2009 | 09:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Checking YouTube now........
Old May 11, 2009 | 08:22 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Well i can say with certanty that electronics + water = bad idea. Also getting water in the motor itself = bad idea. In eather case hoseing down would likely get water into both. Further more not to make matters seem worse hypothetically speaking if you were to drive it into a small pool than the electronics equation is changed alittle electronics + water in the right places + power = death sentence. You can tell how damaging water can be by looking at how hard GM worked to try and keep water out of the engin bay with its weather tight connectors and gasketing material along the hood baffles in the intake i can go on an on and on. Again back to the hypothetical situation dosnt seem like you have alot of options in the matter as its alittle late now but ide deffinetly do what i could to dry it out and change the oil/filter.
BlueIroc-Z
Jun 9, 2019 03:22 AM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:52 PM
Sanjay
Aug 12, 2015 03:41 PM
