oil pressure?
Old May 10, 2009 | 10:56 PM
1987__GTA's Avatar
Car: 1987 GTA
Transmission: 700R4 w/ shift kit
oil pressure?
So at first i thought my oil pressure gauge was broken, until I check my oil. I am losing oil FAST. My gauge jumps in between 30 and 60 sometimes, but is usually on 60. I have no visible leaks, but one of my cylinders compression is a little low.
With all this said, what can my problem be?
Old May 11, 2009 | 12:25 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: oil pressure?
worn out piston rings. How many miles on the car or on the engine? The engine in my car is from an 82 Caprice and has never been torn apart. I'm burning oil and am building a new engine for the car. May be what you need.
Old May 11, 2009 | 01:40 AM
1987__GTA's Avatar
Car: 1987 GTA
Re: oil pressure?
about 180k on body, supposedly 60k on rebuilt engine.
Old May 11, 2009 | 06:15 PM
birdtojag's Avatar
Re: oil pressure?
I wonder if that cylinder has broken rings. 60K is a good amount of miles, but shouldn't be broken yet. Do a cylinder leak down test to see where that cylinder is leaking it's compression.
Old May 11, 2009 | 09:24 PM
1987__GTA's Avatar
Car: 1987 GTA
Re: oil pressure?
Thanks, ill get more detail about that cylinder.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
