86' Iroc Z28 posi?????
Old May 12, 2009 | 09:19 PM
nghanie's Avatar
Car: 86' Z-28 Iroc Camaro
Engine: V8 5.0
Transmission: Automatic
dose a 1986 Iroc z28 have a rear posi?? because when i rearly do burnouts i only see one line in the street. is there somthing i need to do or fix to make it 2 lines in the street?
Old May 12, 2009 | 09:36 PM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
Re: 86' Iroc Z28 posi?????
if you only see 1 mark its most likely worn out.the irocs have a 9 bolt thats for shure a posi but i just took my 9 out put in a 7-5/8 with a powertrax and love it.my 9 used to leave 2 good marks but it slowly died out lol
Old May 12, 2009 | 09:39 PM
nghanie's Avatar
Engine: V8 5.0
ohhh ok so do u think mine died out??
Old May 12, 2009 | 09:42 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You have to pull the inspection cover and look. That's the only way to tell if you indeed have a positraction unit.
Old May 12, 2009 | 09:46 PM
Car: 87 iroc z
Engine: 358 tpi
the powertrax?It locks the rear wheels together in stright line accel with no slip for 2 killer black marks if that what you want to do but i got it so i wont spin so bad comeing off the line
Old May 12, 2009 | 09:48 PM
nghanie's Avatar
Engine: V8 5.0
oh ok so how do i "pull the inspection cover to look"
Old May 12, 2009 | 09:51 PM
nghanie's Avatar
Engine: V8 5.0
oh lol so how much did that cost?
Old May 12, 2009 | 10:00 PM
hwcoll95's Avatar
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
Old May 12, 2009 | 10:03 PM
nghanie's Avatar
Engine: V8 5.0
thats sick, but where did you get those parts??
Old May 12, 2009 | 10:08 PM
hwcoll95's Avatar
Engine: 355 carb'd
Transmission: 5spd
all stock it's an '89 3:08 pos unit
Old May 12, 2009 | 10:11 PM
nghanie's Avatar
Engine: V8 5.0
ohhh ok ok i see so is that a good posi? do both wheels spin when doing a burnout?
Orr89RocZ
Apr 25, 2016 08:28 AM
neekolzun
Aug 24, 2015 04:59 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
mustangman65_79
Aug 11, 2015 03:17 PM
