TPS voltage ....backwards????
Old May 18, 2009 | 02:47 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Hey there, yes I did a search already....but have a different question.
The voltage on a TPS sensor is supposed to be read as follows, and please correct me if I'm wrong:
Key on, put postive probe on middle wire of connector, and bottom wire is ground, at idle the voltage is supposed to be .5v and WOT is supposed to be 4.2v.
Now my question is I check my camaro the same way....but got 4.2v at idle and about .5v at WOT...The car runs good with no check engine light and everything seems normal.....but is this right??? let me know if you can help......thanks in advance.
Old May 18, 2009 | 04:23 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
Transmission: TH700R4
Axle/Gears: 3.23 limited
Re: TPS voltage ....backwards????
pretty sure I was putting the positive on the top wire and the negative on the middle wire to adjust mine..
Old May 18, 2009 | 05:06 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I can confirm, you measure the voltage across A and B. I would set the TPS at 0.60 V for idle, and the full throotle voltage will come out to be whatever it can reach. It should be at least 4.0 V.
Old May 21, 2009 | 05:42 PM
Engine: L98 494hp
sweet, I will try that then....top wire positive at .60v and middle wire is ground....I didn't have a check engine light on but wanted to be sure.....
one more question though.......this is a spare TPS sensor I had sitting around....the one that was on my car had no slots for adjustment, it was a self zero-ing so to speak, this new one has slots on it for adjustment....is it the computer that self zeros or it the type of sensor....both sensors are from camaro's of course, but two different part numbers, I'm suspecting different years but everything seems to be working okay.
Old May 21, 2009 | 08:09 PM
tpi90rs's Avatar
Car: 87 Formula 350
Engine: 350tpi
the adjusting TPS is for MAF controlled TPI's ('85-'89), your non-adjusting is for speed density TPI's.
Old May 21, 2009 | 08:15 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
ECM reads the TPS on startup whatever is lower the old reading, or the new one will be the new zero reference.
But, if you put an ajustable TPS you need to set at .6 volts.
Old May 21, 2009 | 08:17 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
But, if you put an ajustable TPS you need to set it at .6 volts.
Old May 22, 2009 | 08:26 AM
Engine: L98 494hp
I'm assuming it's okay to use a '85-'89 adjustable MAF TPS on my car which is speed density, as long as I have the sensor adjusted correctly??
Old May 22, 2009 | 09:44 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Yes
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
