engine trouble!!!!
Old May 18, 2009 | 03:52 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
engine trouble!!!!
i have a 90 camaro 3.1 it has been sitting 5-8 years so i bought it from a guy who said it jus needed a fuel pump so i put in a whole sending unit and now it starts up but it runs super lean has no power wont get over 15 rough idle. ive checked fuel pressure and it has 45psi wich is fine I checked timing dead on. Ive just ran out of things to do. Any ideas?
Old May 18, 2009 | 03:59 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: engine trouble!!!!
Stuck injectors? Make sure all the injectors are clicking. With the engine running, you can carefully tap on them with a screwdriver handle; this can free them up. It's worked for me on my car.
Old May 18, 2009 | 04:16 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
do u think a injector would make it run that bad?
Old May 18, 2009 | 09:08 PM
Irocz207's Avatar
Car: 90 Camaro RS
Engine: 3.1
bump
Old May 18, 2009 | 09:17 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Did it have gas sitting in it for 5 years? Did you flush the fuel lines and change the filter? Gas turns to a nasty varnish in that time. Check the fuel pressure too.
Old May 18, 2009 | 10:17 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
One might not, but a few certainly would. Old gas can glue the injector needle valve closed.
backtothe80s
Sep 5, 2015 12:39 AM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
