advice needed on timing
Old May 20, 2009 | 07:44 PM
bubbatwo0_0's Avatar
Car: 87 iroc
Engine: five-seven L98
Axle/Gears: 3.27 aussie
If i unplug my wire on the firewall that you set the timing with my car runs perfect, but if i set my timing then plug it up, it gets to idle crazy then stalls out, starts right back up then stalls again?
Old May 20, 2009 | 08:09 PM
1983Zsled's Avatar
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
Re: advice needed on timing
What are you setting the timing at?
What is the correct setting?
8 degree's BTC is what I can see.
Other than that..how did the car run before you re-set the timing?
Maybe something in the ecm or a component that controls fuel/air ratio?
Old May 20, 2009 | 08:37 PM
Car: 87 iroc
6 deg btc with wire unplugged, then clearing memory and reconnecting wire
Old May 20, 2009 | 08:44 PM
1983Zsled's Avatar
Car: 1983 Z28
six or eight degrees isn't that big of a difference. I added a few more questions to my first post. I think you might have a problem with the air/fuel sensors, or the computer not advancing the timing. There should be some other guys that can tell you what the advance should be at idle with the wire plugged in. Depending on the size of your harmonic balancer you should be able to figure out where you should be at.
Old May 20, 2009 | 09:12 PM
Car: 87 iroc
there is no check engine light on or any codes. if it was a sensor id get a code right? and i just replaced the ecm, maf, maf relays, tps, coil, module, iac, all this week. what does the esc module that bolted to the firewall next to the brake booster do? Do you think this could be causing it?
Old May 20, 2009 | 11:16 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
that old obd system has problems telling you when things are failing, only when they have died off. I think?
Old May 20, 2009 | 11:20 PM
Car: 87 iroc
Ive googled the crap out of this and is seems to point me towards a worn out pick up in the distributor. I guess i will swap it out tommorrow. I have a spare one out of a 89 tbi 350, I think there the same
Old May 21, 2009 | 12:19 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
replace the pickup module and the shaft
Old May 24, 2009 | 08:59 PM
Car: 87 iroc
problem solved, I replaced the distributor with the pick up in it and she runs like a dream again.
jhawkeye
May 25, 2022 06:33 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
jharrison5
Aug 19, 2015 05:53 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
