Oil Sending Unit
Old May 25, 2009 | 08:03 AM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Oil Sending Unit
Alright, I need to know what size 12 point socket I need to remove the dummy light version oil sending unit. I swapped clusters and this is the only thing left for me to finish it. I really need to get this done soon.
Old May 25, 2009 | 08:40 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Oil Sending Unit
Sounds like you're going to buy a socket. If so, buy yourself the correct tool:
http://www.harborfreight.com/cpi/cta...112&zmap=95046
Old May 25, 2009 | 09:21 AM
Camaro5690's Avatar
its way bigger than 3/8 my 7/8 wrench wont even fit over it. the only thing that could be that size is the round part on the top with nothing to grip.
Old May 25, 2009 | 09:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Forgot the size.
Why don't you just use channel locks?
Old May 25, 2009 | 09:56 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
3/8 is the ratchet size, not the size of the socket opening. The socket itself is over an inch.
Old May 25, 2009 | 10:01 AM
Camaro5690's Avatar
I realized what I said after I got outside, I got it out, and the new one didnt fit, it hit on the intake manifold, now I have to return it and try to get the correct one.
Old May 25, 2009 | 10:48 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
If you're switching from the dummy light type to a gauge type, you may have to piece together fittings to make it work. IIRC, the oil pressure hole is 1/8" NPT (pipe thread). I have both sending units on my old pickup, it looks ridiculous. ;-)
Old May 25, 2009 | 11:02 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Yep, the hole is 1/8" NPT. Head down to your local Lowes/Home Depot/Ace Hardware/etc and pick up a brass pipe elbow. 1/8 FIP to 1/8 MIP. Screw the male end into the block and then thread the sender into the female end of the elbow. Make sure you use teflon tape on both sets of threads to prevent leaks.
Old May 25, 2009 | 07:48 PM
Camaro5690's Avatar
Why do they make it like that? Whats different about the manifold on the LG4s with the gauges that would make it fit? Is it just the aftermarket sending unit?
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
