Cam retainer question
Old May 26, 2009 | 10:08 AM
Wildebird's Avatar
Installing a new cam and heads on a ZZ4(roller) blockand just wanted to make sure the stock retainer plate that holds the cam is all I need. If you read Comps install inst. it talks only about the cam buttons and nothing about the retainer plates holding the cam in. Going with an aluminum cover as well. When I took it apart thats all that held it in. I'm thinking the cam buttons are for retro-fit stuff. Am I correct in assuming this? Also anyone have any trouble with the cam gear rubbing on the retainer plate bolts? Mine doesn't touch but its dam close. Summit sent me the wrong chain initially as well. Went with comp 2138 chain and there doesn't seem there would be enough room to run a cam button anyway. The cam gear bolt circle is way too small.
Old May 26, 2009 | 02:03 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Cam retainer question
I've put two cams in my 350 including a ZZ4. No button necessary - the retainer plate will work fine.
Not sure about the gear rubbing. I went with a Cloyes double roller timing chain and it works great.
Hope this helps.
Old May 26, 2009 | 11:32 PM
Wildebird's Avatar
Thanks, I figured this would work fine, just wanted to get a second opinion.
Old May 27, 2009 | 12:24 AM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
when i changed the cam in my LB9 i ended up getting a double roller set for a non roller engine from summit. the bolts were really close to rubbing so i switched to a counter sunk internal hex head bolt now theres loads of clearance.
Cameeeero
Sep 18, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
