remote starter solenoid, now starter noise ??
Car: 85 camaro z28
Transmission: auto to manaul
i just install a remote starter solenoid, now i hear some type of starter noise (like the starter not disengaging soon enough). This is a lt1 starter with a t56 trans. is this common with the remote solenoid?
Re: remote starter solenoid, now starter noise ??
That LT1 starter is probably one of them permanent magnet type starters. they act like a generator when they spin and the current they generate powers the solenoid keeping it closed longer than it should. try removing the jumper and running a separate start wire to the start wire on the remote solenoid and see if that stops the run-on.
Car: 85 camaro z28
do you think i am hurting the starter or flywheel, if i just leave it like that?
Yes. Take a look at this page from Tilton.
http://www.tiltonracing.com/ins/98-297.pdf
You've got it set up like the Ford with a jumper. Some brands of permanent magnet starters have this problem, some brands don't. The instructions for the cheapo one i got said not to wire it with a jumper for this reason. I myself, wouldn't take the chance that I would have to replace a starter and/or flexplate/flywheel.
Car: 85 camaro z28
Thank chesterfield. its looks like my remote solenoild was a waste of money this sux. not to sure wat to do, with my heat soak problem now.
Car: 85 camaro z28
would a relay a help with the heat soak with out jumping the two terminals on the starter?
Gunner242
Dec 25, 2015 04:49 PM
sjorgens
Oct 1, 2015 07:54 PM
