engines almost done, hit a snag
Old Jun 1, 2009 | 06:24 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
so my stock 350 budget build is almost done, untill last night i noticed that the intake manifold i was planning on using is cracked. so my question is can i use the one off of my old l69? i know they will swap but are they the same internally? and if that wont work will the edelbrock torker 2 work with my q-jet? its a 71 350 4 bolt main casting number: 3870010 (i think) and heres my semi finished engine its painted chevy engine orange the camera made it look red
Old Jun 2, 2009 | 09:25 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: engines almost done, hit a snag
Use the L69 intake until you can afford something better. The Torker 2 might be slightly better above 3500 rpm, but putting a Q-J on it isn't good. Save up for an Edelbrock Performer or a Weiand.
Old Jun 2, 2009 | 03:41 PM
Brennan's Avatar
thats what i was planning on doing, because right now i just want the engine reliable. later on down the road when i am no longer an apprentice the motor will be made into something respectable
Fronzizzle
Mar 18, 2019 08:29 PM
mhatfield 14
Oct 24, 2015 07:48 AM
MY87LT
Aug 17, 2015 08:43 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
