What plugs are you running ?
Old Jun 1, 2009 | 06:47 PM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
87 IROC 350 TPI
MSD 6aL
accell Coil
lingenfelter stage 2 cam
and a whole bunch of other stuff irrelevant to the thread.
Its time to change out the plugs and I wondered what everyone was running. I had been running champion truck plugs for a bit but wonder if anyone has had greater successes with other types ? (Iron heads)
Old Jun 1, 2009 | 08:17 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: What plugs are you running ?
AC R45TS, the plug everyone should be using. ;-) Don't buy into that multi-tip hype, the spark can only jump to one place at a time.
Old Jun 1, 2009 | 08:26 PM
bwtaylor84's Avatar
Car: Camaro
Engine: 350 .40 over
Transmission: TH400 TCI
I like the AC 44ts
Old Jun 1, 2009 | 10:01 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
AC R43TS...I think. It's been a long time since I replaced the plugs. When I get ambitious, I'm going to replace them with NGK UR4's. I hope the NGK's will clear the header tubes.
Old Jun 1, 2009 | 10:23 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
AC Delco Rapid Fires
Love em!!!
DONT GET BOUSH!!!!!!!!!!!!!
Old Jun 1, 2009 | 10:35 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Autolite 3924 or 3923, either seem to be fine. Tighter gap than normal though, think .037" otherwise it can't fire the plugs at high cylinder pressures.
Old Jun 1, 2009 | 10:57 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The difference between the AC Delco R45TS, R44TS and R43TS is the plug heat range. The TS means an extended tip which is always recommended. The heat range required for your engine depends on a lot of factors. Run the coldest plug possible that won't foul up. Start with the R43TS plug and if they foul up, put in R44's.
A normal copper plug will perform just as well as all those gimmick plugs but none last forever. Plugs are cheap. It's not worth cleaning and regapping used plugs. When they wear out, just replace them. If you don't like changing plugs every few years, use a platinum plug. They don't wear out as fast as a copper plug.
Racers usually use the NGK race plugs or Autolite plugs.
Old Jun 10, 2009 | 05:48 PM
Car: 1987 IROC Z
I picked up some R44TS, im going to try those out tonight. Are the rapid fires really worth $5 a pop ?
Old Jun 10, 2009 | 05:52 PM
Car: 1987 IROC Z
This became a more pressing issue as I started to hear a knocking under the hood that my brother believes may be a fouled up plug. Thanks for your help guys
Old Jun 10, 2009 | 05:57 PM
one92rs's Avatar
Car: SOLD!!!!!
i am using the ngk version of the r45ts. i have used ngk in all my race engines and really liked the iridiums when i was shooting a 175 to 200 shot of nitrous, even though people dont like them i have never had a problem with them ever. and i believe that the that the ngk v power which are only 1.99.
Old Jun 10, 2009 | 06:34 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
AC delco R43TS's here.
Old Jun 10, 2009 | 09:04 PM
89RS_82Z's Avatar
IDK but my car ran so much better with rapid fires, and the plugs there were in it were fairly new autolites
Old Jun 10, 2009 | 09:14 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
AC Delco Rapid Fires.
Old Jun 10, 2009 | 09:19 PM
racerquinny's Avatar
Car: 91' camaro rs and an 87' trans am
Engine: stang eater..slower ones. lolololol
Transmission: 700r4-camaro t5-trans am
Axle/Gears: stock :(
i hear what ever chevy came with in the firstplace, i belive its ac delco. aftermarket stuff is good, i dont think you need three electrodes to center the spark.
IMO that is.
Old Jun 13, 2009 | 11:13 AM
Car: 1987 IROC Z
Dude... WTF... day 3, AND I STILL CANT GET TO THE FREAKIN PLUG!!!!
Not the passenger side amazingly... the driver side... I can see it, I can touch it, I just cant get past my hooker headers and I need this before monday. I think this will be a tale to tell as im currently trying to find a bit strong enough to dig into the backend of a Kobalt spark plug socket...
just venting more than anything else.
Old Jun 13, 2009 | 11:31 AM
AlkyIROC's Avatar
Car: 87 IROC L98
It takes me about half an hour to pull all my plugs to inspect them. It takes longer to put in new plugs because I have to index them. I use a spark plug socket that has a hex on the end. I need to tighten and loosen the plug by putting a 3/4" wrench on the end of the socket because there's no room for a ratchet, extension or any kind swivel adapter.
After loosening the plug, I then use a chunk of 1/4" heater hose to slip over the plug and screw it out. There's no other way for me to access the plugs.
If your plugs are that difficult to access and you have no reason to access them regularly, install some platinum plugs.
Old Jun 13, 2009 | 11:55 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I have to take the #6, #7, and #8 plugs out from the bottom.
Old Jun 13, 2009 | 03:21 PM
Car: 1987 IROC Z
DONE ... 3 days... Im just going to start a post about the whole process. I basically had to go through a series of bits, and 2 chopped sockets... crazy stuff. Thanks for the help guys.
Old Jun 13, 2009 | 03:23 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
Amen brother!!!
mine gapped at .037 instead of .035 for a little extra spark to go with my MSD coil.
Old Jun 14, 2009 | 09:57 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
I use the delco stuff that you get from autozone...
Old Jun 14, 2009 | 10:32 PM
89RS_82Z's Avatar
Originally Posted by Xlr8torZ28
Amen brother!!!
i should prob take mine out and regap them to .37 to with the MSD, i dont know but i do love the AC delcos
only thing i may try is a set of E3's, i have really good luck with them in small air cooled engines
Old Jun 15, 2009 | 06:48 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
NGK UR5's gapped at .032" with a 150 shot of juice! Oh, I forgot to mention that these plugs are shoter then the std. A/C plugs which helps with headers.
Auggie
Old Jun 15, 2009 | 08:17 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Auggie
Same plugs here. Gap at .035 and no juice.
Old Jun 29, 2009 | 01:25 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
im running ngk iridium ix plugs they replaced a set of rapid fires and i noticed a big improvement on acceleration
Old Jun 29, 2009 | 01:49 PM
Hoffy91's Avatar
Car: 1982 Trans Am/1989 Iroc Z
Engine: T/A:1974 Corvette 350, Iroc:305 TPI
Transmission: T/A:Borg Warner 5-Speed, Iroc: Auto
Axle/Gears: T/A: Dana .44, Forgot Iroc
I'm running ac delco R43TS plugs on my nitrous Trans Am. Works like a charm handles anything.
eightsixseven
Dec 16, 2024 01:50 PM
rocn7roc
Sep 21, 2021 02:16 PM
apo_bailon15
Mar 28, 2016 05:20 AM
1989formula5.7l
Aug 17, 2015 02:56 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
