should I have to use mid grade for LG4 86 IROC?
Old Jun 5, 2009 | 09:42 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My 86 IROC has a what seems to be a bone stock lg4. I get some spark knock when I use regular. Not real bad ping, just when I excelerate I get a rdddddd, or something like that.
Old Jun 6, 2009 | 06:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: should I have to use mid grade for LG4 86 IROC?
None of these cars require anything more than regular from the factory.
If you're getting knock then you have a different problem.
Old Jun 6, 2009 | 11:08 AM
acole88's Avatar
check your timing
Old Jun 6, 2009 | 11:54 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Timing is too far advanced.possibly. i use premium 93 in all my vehicles ONLY!!
Old Jun 6, 2009 | 04:47 PM
Why do you only use 93? I would think I would get better performance out of my tbi w/93 since I have a spark knock sensor.. the lack of knock, the more the timing should stay advanced.. Do you know if this is the case?
Old Jun 6, 2009 | 09:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check your EGR valve. It isn't uncommon for the exhaust passages of the EGR circuit to get plugged, which will give you pinging under light acceleration.
But check the timing as well. Unless it's been moved, though, that shouldn't change.
Old Jun 6, 2009 | 10:42 PM
Car: 1986 Iroc z
Engine: 350 tpi
I only use 93 because my car seems to perform better. Thats a matter of preference. Some people have better luck with 87 octane. Most manufactures reccommend 87. Although i had a 94 Cadillac eldorado and the book said to use ONLY Premium 93 octane in its Northstar v8. I would check the things that 57kid said as well. Also if your knock sensor has not been changed i would change it anyway. every little bit helps. good Luck
Old Jun 6, 2009 | 10:47 PM
Car: 1986 Iroc z
Engine: 350 tpi
Also remember if you check your timing make sure you unplug the wire that goes to the distributer before you set your timing. Then plug it back in afterwards after timing is set.
mdtoren
Aug 23, 2015 12:52 PM
g.l.mos
Aug 22, 2015 12:02 AM
mdtoren
Aug 16, 2015 05:45 PM
mustangman65_79
Aug 11, 2015 03:17 PM
