Car won't start v10284532
Old Jun 6, 2009 | 04:18 PM
FLYNLOW92rs's Avatar
Old Jun 6, 2009 | 07:32 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: Car won't start v10284532
You tried to jump start the car but had no luck. Did you try to jump the starter? Do you have VATS bypassed or is it functional?
Old Jun 7, 2009 | 10:43 AM
Old Jun 7, 2009 | 11:13 PM
g_port's Avatar
Car: 1984 camaro
Engine: 355 mild mods
Transmission: 700r4 bone stock
Axle/Gears: posi
forget jumping the stater, you more than likely have a busted starter solenoid about the only thing you can do to get it started again is bang on the starter with a hammer, and that only if you are stranded. so just cut your losses and buy a new starter it will safe you a whole lot of time. i had this same problem and got stuck twice in the middle of no where before i gave in and bought a new one, fixed the problem instally, good luck
Old Jun 8, 2009 | 03:08 AM
91rsinnm's Avatar
Car: 91 rs
Engine: 305 tbi
Transmission: t-5
I had the same thing happen with mine, and we found a faulty relay that is located behind the driver side kick panel. My dad ended up just by passing it somehow but it works now.. gl
Old Jun 8, 2009 | 04:30 AM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Both of the previous posts are example of people jumping to conclusions, don't hop on the floor banging on your starter.
I experience this problem every once in a while, usually in the winter when it's cold. I turn the key and nothing happens, no crank. I believe it's a bad ground cable, but I'm not certain because if that's the case then why is there still power to the accessories?
But anyway, you can determine whether your starter's good by getting some sort of voltage tester and testing the voltage at the terminal on the starter, or you can just unbolt it and take it to autozone, they will test it for free there.
If it's the starter, great, you've found the problem, half the battle's (which in most cases is the most difficult part) been won. Now you can replace the starter.
However if it's not that then there are many different things it could be, vats like they previously mentioned, a problem with the ignition switch perhaps, or wiring somewhere along the line.
Test the starter.
Old Jun 8, 2009 | 09:41 AM
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
