which one of these starters should i buy?
Old Jun 7, 2009 | 07:28 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
i need a new starter, my cheap lt1 starter has once again died. I am looking for a good starter for my t56 trans. I was thinking the Hitachi Enforcer Mini Starter or the Summit SUM-829100 Mini High-Torque Starters. My budget is somewhere around 150. which one of these are the best for my setup?
http://tpiparts.net/inc/sdetail/10338
http://store.summitracing.com/partde...5&autoview=sku
Old Jun 7, 2009 | 07:53 PM
aweTastic's Avatar
Car: 1989 Camaro IROC-Z28
Engine: Rebuilt 350TPI (see sig)
Transmission: is being replaced...
Axle/Gears: 20 year old G92 Borg-Warner 3.45
Re: which one of these starters should i buy?
I went with the Summit SUM-829000 which is really similar to the summit one you listed just has a higher suggested compression ratio cuz Im running 11.5:1
Its supposed to be here tomorrow Ill let ya know how it works
Old Jun 8, 2009 | 07:58 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I've been using a Summit mini starter 820323 for about a year and it has been great. I used to have hot-start issues where it would crank really slow, if at all, but not anymore. I will never go back to a stock starter.
Old Jun 8, 2009 | 08:59 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I broke 2 of those LT1 starters... just ended up with my old giant starter on the car.
Are those LT1 starters really this notorious for breaking?
Old Feb 4, 2010 | 11:32 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
any news on how those mini starters are holding up??
Old Feb 4, 2010 | 01:47 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Mine's still fine.
Old Feb 4, 2010 | 01:53 PM
Jeffs82TA's Avatar
Just buy a 88-91 corvette mini starter. In 100 degree days and 220 degree operating temps my 90 vette cranks over without a problem. You can buy them pretty cheap.
Old Feb 4, 2010 | 02:59 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
are you actually breaking the casing or are you just having issues with the solenoid dying? A remote solenoid setup will set you back no more than $50 and you'll probably be able to use the "dead" starter you already have
https://www.thirdgen.org/solenoid
that's exactly what I did on my last car after going through 3 starters in 1 month. didn't have to do another one til I sold the car.
Old Feb 4, 2010 | 03:02 PM
mgilorma's Avatar
Car: 90 RS
Well actually my starter did work until I tried to remove the connections when pulling the engine and the selenoid fell apart. But I was thinking about getting a smaller one just because I'm not sure about headers yet and thought a smaller one would have less fitment issues when the headers go on.
Old Feb 4, 2010 | 03:23 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
ok, then completely disregard my post
nothing to see here.........
Old Feb 4, 2010 | 03:54 PM
mgilorma's Avatar
Car: 90 RS
that is acutally a cool idea, bookmarked that one for later.
Also I'm looking at one of these two starters, can't figure out which one is smaller:
http://www.summitracing.com/parts/SUM-829100/
- or -
http://www.summitracing.com/parts/SUM-820323/
Old Feb 4, 2010 | 05:12 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I have a 100K one on my 12:1 383 and it cranks fine regardless of engine temp
Reman with 1 year warranty on eBay for $75
Old Feb 7, 2010 | 10:36 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
I run a standard powermaster ministarter with a heat blanket, no issues with heat soak, always cranks over good, never had a problem
gta892000
Aug 11, 2019 11:16 AM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
bbsr72
Sep 27, 2015 05:55 AM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
