engine misses or cuts out
Old Jun 7, 2009 | 10:12 PM
87firebirdformu's Avatar
I have an 87 Firebird, 5.0L TPI equipped car. The engine idles fine, starts fine, but once warmed up, it sometimes misses. This can happen when you go to accelerate, or just crusing along at a steady speed. It's as if for a second the engine shuts off. Sometimes when this is happening the tach jumps up, all though the engine speed is not. So far I have replaced the fuel filter, cap and rotor and have tried a new MAF sensor.
Old Jun 8, 2009 | 11:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: engine misses or cuts out
Check the injectors, especially if they're the stock ones. Get an ohm meter and measure the resistance of them when they're cold and again when they're warm. They tend to fail as they get hot, and will either dribble too much fuel, or shut off and not squirt any fuel.
When cold they should measure around 14-16 ohms and when warm they should be more than 12 ohms.
Old Jun 10, 2009 | 02:02 PM
M@88iroc's Avatar
Car: 1988 Camaro IROC Z28
Engine: 5 Litre V8
I hav this same fault! Tacho jumps afteer 2000 RPM, can cut out and fail. What hav u found if anything yet?
Cheers Matt
Old Jun 24, 2009 | 07:25 PM
Yes got the car fixed. Took it to a Midas shop and was lucky to find an older mechanic who had worked on these cars before. He tested a few sensors scanned it etc and found nothing wrong. Then, he sprayed some water over the distributor cap and held a grounded screwdriver close to it. When the screwdriver came within an inch of the cap the engine slowed down and started missing. A new cap, rotor, spark plug wires, plugs and coil and the car runs like new.
Also fixed were ratling rear pads. There is a clip, GM calls it a spring, one side of which goes on the piston, the other attaches to the pad. Seemed only this guy out of all I had talked to, including dealers, knew they existed.
Old May 3, 2010 | 06:47 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
What is the object that you mentioned above in red (clip/spring)?
Old May 5, 2010 | 07:28 PM
Hi.
I beleive they are called anti rattle clips, or spring. Phone a Chev dealer and they should be able to look it up for you. After market stores I don't think will have them. If your rear brakes are rattling and stop when you just touch the brake lightly, I would think you are missing them.
Old May 5, 2010 | 08:13 PM
K. Ill do that tommorrow.
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
