Is this valve float??
Old Jun 8, 2009 | 06:01 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Can somebody tell me if this is valve float??? cam is supposed to peak at 6000 rpms
Old Jun 8, 2009 | 08:54 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Is this valve float??
Could be. What cam? What valve springs?
Old Jun 8, 2009 | 09:21 AM
Car: 92 Camaro
Axle/Gears: S60 373
Lloyd Elliot custom cam...supposed to peak at 6000 rpms....
Springs are Howard something..... it was the springs he suggested... good for (I believe) .630 lift 350lbs of pressure...yadda yadda yadda....bottom line, the guy that ground the cam for me said use those springs and we all know the Lloyd knows his stuff
Old Jun 8, 2009 | 10:15 AM
AlkyIROC's Avatar
Car: 87 IROC L98
If the springs are the ones recommended for the camshaft and they're installed properly, then they're not floating. Having the correct springs and having them coil bind, won't give you full lift and will cause damage.
Are the heads and valvetrain set up to allow the lift of the camshaft? Is the piston to valve clearance enough?
Without knowing much about the head or engine setup, it's hard to make a guess as to what might be wrong.
Never heard of Lloyd Elliot. Never heard of Howard something springs. Most people use normal brand components like Comp Cams, Lunati etc. If you have no specifications, names mean nothing.
Old Jun 8, 2009 | 10:57 AM
Car: 92 Camaro
Axle/Gears: S60 373
Lloyd Elliot elliotportsworks.com pretty popular on ls1tech.com and other lt1/ls1 sites.
Heads are AFR 195cc the old ones how can i tell if i have coil bind?
Old Jun 8, 2009 | 03:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
With the valve at full lift, there should be a least .060" between all the coils.
The gap between the top of the valve guide and the bottom part of the spring retainer should also be greater than the valve lift or else the retainer will hit the guide.
Maybe you should be contacting Lloyd Elliot and asking him why his cam isn't making the power it's supposed to.
pjsparts
Oct 29, 2025 06:39 PM
355tpipickup
Sep 13, 2015 11:35 PM
Springster
Sep 13, 2015 01:38 PM
sandman92084
Sep 12, 2015 10:27 PM
Formula_88AE
Sep 3, 2015 01:47 PM
