Lets play, Why arent i getting fuel to the engine...
Old Jun 15, 2009 | 05:38 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
I have great spark, Accel Wires and Delco Plugs.
I spray in starting fluid, and it goes for about 3 seconds...
Which indicates no fuel to the engine.
Keep in mind, this car has been sitting for 6 years.
What could prevent fuel from getting to my engine.
Bad pump?
Bad filter?
Bad injectors?
Clogged lines?
Fuel shut off switch?
Help me please? I really need to have my bluebird running.
Old Jun 15, 2009 | 09:34 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Re: Lets play, Why arent i getting fuel to the engine...
Bump?
Anyone help?
Old Jun 15, 2009 | 09:43 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
well do you hear the elect fuel pump cycle?
how about this - unplug the line from the fuel rail have someone get in the car. have the line pointed into a gas container and turn on the power. if the electric pump is working you will get gas in the container. if not then connect the line and work your way back. disconnect just before the filter. do you get gas? if you do its a cloged filter. if not go to the tank.
6 years is a lot of time for all that crap to settle in the tank. when you put gas into it you got it all floating around - so pull the tank plug and dump the gas. see how bad it is. is it like sludge?
pull the fuel pump and see if it is clogged. while you have it out put power to it to see if it cycles. if not - you need a new pump, but clean that darn tank out first.
Old Jun 15, 2009 | 09:45 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
I have drained the tank. Its clean.
Where is the fuel filter on this car?
Wheres the line to the fuel rail?
Yeah, The gas was RANK. The worst ive ever encountered.
Old Jun 15, 2009 | 10:25 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
WOW! You don't have gas-you have varnish!I don't know how to clean out the injectors.Don't put that gas back in.(Not that you would since it smells bad and is OLD)After replacing the filter and pump I hope it fires up for you! Good Luck
Old Jun 17, 2009 | 04:35 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Yeah no **** eh?
Varnish Yes, It was.
Thanks man, It will.
Old Jun 17, 2009 | 11:29 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
i would recommend some injector cleaner and highest octane pump gas u can buy for at least half a tank. Hope your injectors aren't clogged. Not sure on the fuel rail or filter. sorry
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
PestilenceIV
Aug 20, 2015 03:32 PM
86White_T/A305
Aug 17, 2015 12:16 AM
