Cam replacement and valve stem seals
Old Jun 18, 2009 | 01:18 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Hey guys, I have an old LG4 305 that i plan on killing basically. (350's on a stand waitin for the 305 to breathe its last.) Engine has 86k on the clock.
I got a LT1 cam from a friend of mine for 30$, the cams got a good 50k on it.
I was wondering what is the easiest way to replace the cam in the 305, and what are the steps involved? Is this possible without pulling the motor?
Also, the old 305 smokes on startup (valve stem seals), how do i go about figuring out which seal is leaking. And how would I go about replacing it (or all of them) without taking the heads off, or the motor out of the car.
Thanks a lot guys!
Old Jun 18, 2009 | 01:37 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: Cam replacement and valve stem seals
LT1 cam won't have a fuel pump lobe to drive the mechanical fuel pump, so if you want to install the LT1 cam, you'll have to find some form of electric fuel pump.
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
