I think i killed it...again ._.
Old Jun 20, 2009 | 02:58 AM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
So after another night of tweaking ends with a dead car once again. 92 camaro rs with lt1 tbi swap. Got my car from the tranny shop last night, running good but idling round 1700. Found that my edelbrock manifold had a massive leak. Spent all day today taking it off and redoing it. Tightened up my rocker arms a lil bit. and did other minor adjustments here and there. Went to go start my car and all i got was a loud backfire. Sounded like a shotgun going off. Ive checked all the vacuums and sensors cant find any reason for this. Wasnt doing it before. Whatd I screw up this time? -_-;
Old Jun 20, 2009 | 12:12 PM
crusinman2002's Avatar
Car: 1989 Camaro RS
Engine: 305 for now
Axle/Gears: stupid open diff. 2.73 i think
Re: I think i killed it...again ._.
did you take the intake manifold off? if so, you had to take the disty out, and it could be back in wrong. if you took the disty out, then put the #1 cylinder at top dead center, and make sure that both rockers for #1 move around (not pushing a valve open). then check your disty, it should be pointing at #1 on the cap. if it isn't, then pull it and turn it so that it does.
if thats not the problem, then you might have tightened the rockers a bit too much. that would cause u to loose compression, and backfire.
let us know your findings and the fix
Old Jun 20, 2009 | 03:20 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Turned the dist and it started right up...and died XD. Thanks for dist tip. Car runs aslong I hold the gas somewhat down, running really rough. Soon as I let off the gas it dies. All vacuums are plugged. Starting to wonder if the rtv I layed down on the manifold is holding. Any suggestions to the running rough and dieng problem before I rip the manifold off and do it again?
Old Jun 20, 2009 | 05:58 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Where did you put RTV and how did you go about "tightening" the rockers? What part of town are you in?
Old Jun 20, 2009 | 07:38 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
NorthWest side of Houston. Rtv at the back and front of the block. Regular gaskets for the Intake Manifold. Maybe 45 to 90 degree turn for the rocker arms just to get some rattle out of em.
Old Jun 20, 2009 | 07:54 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Is there a vacuum line going to your map sensor?
Old Jun 20, 2009 | 07:55 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Yes and its attached.
Old Jun 20, 2009 | 07:59 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
The front and rear "china wall" seals are oil seals only. The worst they can be responsible for is massive oil leaks, but not air leaks. Are you sure you got your wires all back on right? How about the timing, have you played with it perhaps advancing it some more or checking it with a light?
BTW, if you took all the wiggle play out of your rockers, then they're too tight.
Old Jun 20, 2009 | 08:15 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Alright well Ill go play with timing and see if I can get my rocker arms back to normal. Thanks for the idea. Ill let yall know how it goes.
Old Jun 20, 2009 | 09:46 PM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Played with the timing for a bit, It got better but still has some issues. Thanks for advice
Old Jun 20, 2009 | 10:07 PM
1brd2brd3brd4's Avatar
Car: 93 Formula,88 T/A,01 WS6
Engine: 93 LT1,88TPI305,01 LS1
Transmission: 93 700R4,88 700R4,01 T56
Axle/Gears: 93 3:73's,88 3:42,01 3:40
LT1 TBI?
Old Jun 21, 2009 | 03:27 AM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Originally Posted by 1brd2brd3brd4
LT1 TBI?
Yes
Old Jun 21, 2009 | 10:08 AM
ericjon262's Avatar
Yes
please, do explain, I'm interested. when you say LT1 do you really mean Lt-1(note the dash), as in the late 60's 302's and 350's?
Old Jun 21, 2009 | 10:31 AM
Milliardoj's Avatar
Car: 92 camaro
Engine: 350 TBI
Yes, see whata happened was.. Too lazy to put the dash in?
Old Jun 21, 2009 | 04:03 PM
I'll call shinanigans on that one......
Old Jun 21, 2009 | 10:25 PM
ericjon262's Avatar
corey8084
Sep 17, 2015 02:56 PM
InfinityShade
Sep 5, 2015 06:38 PM
FireDemonSiC
Sep 3, 2015 12:31 PM
solocus
Sep 2, 2015 12:14 PM
InfinityShade
Aug 22, 2015 08:00 PM
