oil filter help~!!!
Old Jun 20, 2009 | 08:18 PM
Fmaro's Avatar
Car: 1987 Camaro T-top
Engine: current 305(LG4) awating 400ci sbc
Transmission: Current 700r4 awating T-56
Axle/Gears: stock LSD 3.23s?
oil filter help~!!!
hey guys..its been a while since ive posted
I am totally stuck! i have being trying to get the oil filter of my sbc (i know it sounds simple) but basiclly i cant
when i got the enigne it was a lil crushed(from the guy who put weight on if for a second putting the engine on a floor stand
i tryed an oil filter wrench, bent/broke two of them , so then i tryed to force a smaller wrench on, ended up starting to crush the filter
tryed by hand, no luck
YES I AM GOING THE RIGHT DIRECTION i made sure of it many times
so i tryed the old screw driver threw the filter to twist if off....no luck, just made holes
the engine is now on a stand, up side down with the oil pan off...so i have pretty good space around it
DOES ANYONE ONE HAVE ANY IDEAS!!!?!?!?!?!
i was thinking of putting some solvent around the bottom where the rubber gastket is and letting it sit for a while (hoping it would eat away at the rubber)
this was NOT one of the areas i anticipated me stressing over during my build
Old Jun 20, 2009 | 08:57 PM
Guest
Guest
Posts: n/a
Re: oil filter help~!!!
Cut the can off as close to the base as possible. You will then be able to see the end flange, there are a bunch of holes in it for the oil to pass through. Use a screwdriver and hammer and tap the thing around the center using those holes and you should be able to get it off.
Old Jun 20, 2009 | 10:17 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Done the above method. Crazy but it works well.
Screwdriver through the filter didn't work, huh? Must be froze on pretty good.
Old Jun 20, 2009 | 11:04 PM
Fmaro's Avatar
i got it! thanks for all the help
you have no idea...i took the above method but had to upgrade to a heavy duty 1 inch think drift (or punch or chisel, whatever you want to call it) some WD-40 on the treads, a lil prying on the seal, and about half an hour of hammering with a good size ball pein
Old Jun 20, 2009 | 11:09 PM
Stephen's Avatar
Car: 87 GTA
Were the threads, on the oil filter mount, messed up when the engine was set down, by the weight of the engine pushing on it?
Old Jun 20, 2009 | 11:17 PM
Fmaro's Avatar
im kinda thinking thats might have what happened, but the treads on the mount look fine, also i checked them by putting on a new filter on, which was fine on and off
Old Jun 21, 2009 | 12:58 AM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
I know it's already taken care of, but I had this problem once and I used the biggest channel locks that I could fit under there and reefed like hell. haha.
Old Jun 21, 2009 | 05:24 AM
Fmaro's Avatar
that would do it....luckly for me i had the engine on a stand upside down with the pan off...so i had pretty decent space to work with...if this engine was in a car...there would have been no way i would have got it off
Old Jun 21, 2009 | 10:50 AM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
I just figured I'd throw that one in there for that wonderful search function that no one ever uses. ha ha (as I look at another car won't start thread)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
