CHANGING ROCKER ARM RATIO FROM 1.5 TO 1.6
Old Jun 25, 2009 | 08:30 AM
nick86bird''s Avatar
Car: 1984 Trans Am
Engine: 383 4 bbl
Axle/Gears: eaton posi w/ 4.11's
383 STROKER WITH VORTECH HEADS. THE HEADS CAN TAKE UP TO .550 VALVE LIFT BUT THE LIFT IS CURRENTLY ABOUT .500. IF I CHANGE THE RATIO TO 1.6 WILL I GET MORE LIFT AND THEREFORE MORE POWER?
Old Jun 25, 2009 | 09:31 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: CHANGING ROCKER ARM RATIO FROM 1.5 TO 1.6
If you switch from a 1.5 roller rocker to a 1.6 roller rocker, you'll make around 5 more HP.
If you switch from a stamped steel 1.5 rocker to a 1.6 roller rocker, you'll make a bit more than that.
Old Jun 25, 2009 | 10:45 AM
Car: 1984 Trans Am
Engine: 383 4 bbl
yea i probably going with some aluminum roller rockers. so wil 1.7's give me 10 hp haha?
Old Jun 25, 2009 | 12:23 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If you switch to larger ratio rockers you'll have to watch for your valve train geometry too. Your pushrod length will come in to play here. Assuming your valve lift is right at .500" with a 1.5 ratio rocker, a 1.7 will put you over your max lift at .566"
Old Jun 25, 2009 | 12:41 PM
AlkyIROC's Avatar
Car: 87 IROC L98
I don't think there are any 1.7 rockers for a Gen 1 SBC. It would put the pushrod even closer to the pedestal. The guide hole through the head only allows so much movement.
BBC use 1.7 rockers but the rocker pedestal is also a different distance away from the valve.
Aluminum rockers are not the best choice except when used in a street engine. If you survey it, you'll find most people with performance engines prefer Comp Cams Pro Magnum rockers. Even I broke a Crane Gold rocker back when I had a SBC. High end rockers are shaft mount like Jesel and T&D. Expect to pay around $1000 for a set.
Old Jun 25, 2009 | 01:41 PM
Car: 1984 Trans Am
Engine: 383 4 bbl
Thanks for the advice. I'll probably just go with some aluminum 1.6 rockers. I mainly use this engine on the street and im not lookin to spend anywhere close to $1000. a nice $300 set from jegs should do nicely
Old Jun 26, 2009 | 04:44 AM
I don't know if they make a 1.7 either, the highest I can find is a 1.65. http://summitracing.com/parts/LUN-85320LUN/
db057
Sep 4, 2015 07:57 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
