Vortec heads, Patriot Performance?
Old Jun 26, 2009 | 10:43 PM
Curtisyz54's Avatar
Car: 84 z28, 86 irocz
Engine: LS6, 305 TPI
Transmission: TH350, T56
Axle/Gears: 3.73, 4.10
Well Im doing a 383 build, And trying to get away from my l98 heads.
Im really into the vortecs But wanted bigger valves (like 2.02 intake 1.60 exhaust) and Found these Patriot Performace Vortecs with the Bigger valves and there only $630.
Anyone use these? any imputs, if I get some good feedback im deffinatly going to buy them.
http://www.jegs.com/p/Patriot-Perfor...92214/10002/-1
Old Jun 27, 2009 | 07:37 PM
Sooner's Avatar
Car: 1982 4cyl 4spd/ 1980 z28
Re: Vortec heads, Patriot Performance?
It kinda depends on your camshaft selection. If you are under .470-.480 lift or so, then go with vortecs. The heads you are showing only flow 4cfm better @ .500 lift than the stock vortecs on the intake side, and it took them a 10cc bigger intake runner and 2.02/1.60 valves to get that. Used vortecs bring around $200 or less on craigslist.
on the other hand, if your lift is over the .470-.480 mark then I would no doubt go for the patriots, or even a set of RHS vortecs.
If you were to get the gm vortecs machined to accept higher lift, you are gonna have as much, if not more in them as you could buy a NEW set of aftermarket heads for.
Old Jun 27, 2009 | 11:33 PM
Curtisyz54's Avatar
Well new vortecs from gm are $600, thses are $630. So im going to go with these, Im going to get the comp 292h, .501 lift.
Old Jun 28, 2009 | 05:05 AM
Sooner's Avatar
I just assumed you were talking about a used set of vortecs. $600 vs $630 for aftermarket heads with screw in studs and good valvesprings is a no brainer.
Old Jun 28, 2009 | 04:14 PM
Curtisyz54's Avatar
nope these..
Old Sep 7, 2009 | 09:18 PM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
I am thinking about going with these Patriot heads as well. Do you happen to have the complete flow numbers of stock vortec heads so I can compare?
Old Sep 7, 2009 | 09:37 PM
Sooner's Avatar
I belive you will find what you are looking for on this site.
http://www.purplesagetradingpost.com...fo/heads1.html
Old Sep 8, 2009 | 06:04 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
very much sir.
Does anyone here have any experience with these Patriot heads?
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
