engine teardown, what to look for?
Old Jun 27, 2009 | 04:02 PM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
Just pulled the engine a couple of nights ago and am hoping to start tearing down the 305 as soon as I get an engine stand. The engine has about 120k on it and a suspected blown head gasket. What other kinds of things should I be looking out for?
The plan as of right now is to tear it down, clean it up, and put a new gasket set in it. Don't really have money for any upgrades, I am going to get headers, remove the AC and A.I.R system. But other than that just want to clean it up and get it back on the road.
Any tips or suggestions would be greatly appreciated!!!
Old Jun 27, 2009 | 04:21 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: engine teardown, what to look for?
Just gaskets- not rings and bearings? Clean old gasket residue completely. I like to clean with acetone or laquer thinner. If you use this stuff, DO NOT GET IT IN THE ENGINE unless you are doing a cmplete rebuild. Don't gouge any surfaces. Use a scraper NOT a screwdriver when you can. If you know someone who works in a shop,ask them if they would clean the heads. And have fuunn!
Old Jul 1, 2009 | 09:35 PM
mgilorma's Avatar
Car: 90 RS
I'm trying to keep costs as low as possible, so I'm hoping to not touch the bottom end.
I was about to pull the heads off tonight, but after removing the pushrods and head bolts I couldn't get the head off. Anybody have a hint about getting the heads off? I put the handle of a breaker bar in the exhaust port and tried to lift up but to no avail.
Any tips would be appreciated!
Old Jul 1, 2009 | 09:46 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
If you are absolutely sure that you have removed all 17 bolts from the head, then you'll have to pry harder. You can try beating on the head with a rubber mallet.
Old Jul 2, 2009 | 10:45 PM
Car: '87 Camaro
Check for bolts in the corners where oil tends to pool. It may be possible to overlook them because of the oil. My own experience is to smack the head on the intake side and pry from the exaust side--careful not to damage the valves! (( It would be a good idea to have someone help--they can help eye the head if it comes up so you can move to the other end--also to help handle them if they lift and you're off balance)) They're not very heavy but just to be safe! A dropped head can't be too much fun!!
Old Jul 7, 2009 | 05:31 PM
mgilorma's Avatar
Car: 90 RS
I got them off by hitting a piece of 4x4 with a two pound hammer.
I got the engine down to the shortblock and found that I need a new timing chain. Other than that I don't even know what to look for, so if anybody has any other input as far as what to do next, I'm all ears!
thanks!
Old Jul 13, 2009 | 07:20 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Look for any gouges in the cylinders to show the ring are still sealing and maybe clean the carbon off the top of the pistons
Old Jul 31, 2009 | 04:15 PM
HtOwNs 87Rs's Avatar
update and pic would be great.....as im tearing into mines soon
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
