quick 350 ID?
Old Jun 29, 2009 | 02:52 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
quick 350 ID?
Hey, I'm heading out to look at a Camaro tonight, it's a 5-speed Z-28 and the owner claims it's a 350. I know it didn't come that way originally, is there a quick and easy way to tell if it's a 350 or 305 without looking up casting numbers?
PS. I searched and came up dry, apparently "identification" is either too long or too common a word for the tgo search function. Google search only pointed to casting numbers.
Old Jun 29, 2009 | 04:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: quick 350 ID?
Since the VIN number only means what engine was originally in the car, the only way you're going to know if it's a 350 or 305 block is by the casting number.
Depending on the year of the engine there also may be a 5.0L or 5.7L cast into the side of the block.
The last thing to check is the suffix code on a pad in front of the passenger side head.
Just looking at the engine will only tell you that it's a SBC and nothing about the size. Externally all SBC engines look the same except a 400 block which will have an externally balanced engine dampener or a 383 with a 400 crank.
GM never produced a 5 speed with a 350 so something has been changed. There were a lot of 305 Z28's with a 5 speed.
Old Jun 29, 2009 | 04:13 PM
el_muerte's Avatar
Car: '87 Z-28
Re: quick 350 ID?
Yeah, I knew the 305 and 350 look identical and the 5-speed didn't come with the 350 originally. The part with the 5.0/5.7 cast is what I was after... what years was that done, and where specifically would it be located? Thanks
Old Jun 29, 2009 | 05:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Re: quick 350 ID?
I think when they switched to a one piece rear main seal in 1986, the casting on the side of the block was added. It's right on the side of the block.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Infested
May 22, 2018 11:56 PM
Eric-86sc
Aug 24, 2015 09:01 PM
NinjaNife
Aug 23, 2015 11:49 AM
crazynights
Aug 21, 2015 06:53 AM
