083 or 187 heads
Old 07-02-2009, 05:40 PM
wannaz's Avatar
Car: 90 iroc z
Engine: 350 needs work
Transmission: 700r4 needs work
083 or 187 heads
Since i cant find a decent set of 083 will 187 heads work as well as 083 heads on my tuned port.
Old 07-03-2009, 07:33 PM
doc
doc's Avatar
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: 083 or 187 heads
I know that 14101083 heads came factory on the '87 Camaro IROCZ 350. These are 350 heads. These are 4.00" bore heads.
If the other number in full is: 14102187 then these are '87-'91 305 heads. These are 3.74" bore heads. I do not think that these heads will work on your 350.
Old 07-03-2009, 11:16 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The 187's would "work" on the 350, as in bolt on, move air, and whatnot. But, being the 305 swirlies, I don't know how prudent of an idea it would be. I would keep looking for a different set of castings, personally.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
FormulasOnly
09-06-2015 10:42 AM
z28guy134
09-01-2015 11:50 PM
Quick Reply: 083 or 187 heads
