driving with no oil cap.
Old Jul 3, 2009 | 12:09 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
drove my formula 600 miles this past weekend. key west for a few days =]
never thought it would make it but it did.
anyways on the way back i drove 130 miles without the oil cap on due to getting distracted topping my fluids off before i came back. no problems but it rained alot and im thinking about changing the oil because of moisture getting in there?
what do you guys think? thanks
Old Jul 3, 2009 | 01:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: driving with no oil cap.
I'd be more worried about dirt and dust than moisture.
Old Jul 3, 2009 | 02:16 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I agree with Apeiron. I'd worry about contaminants. I think its too hot for moisture to even build enough to make a problem inside the engine. I'd also worry about some oil possibly spewing out. But just top it off and don't make a habit out of leaving the oil cap off...
Old Jul 3, 2009 | 11:59 PM
Car: 90 formula
Transmission: auto
alright. yeah nephew almost fell in pool when i was pouring oil in it. didn't lose any oil however. i checked it as soon as i put the cap back on.
remembered when driving. one of those things when your like fawkkkk i dont remember doing it. but thanks guys!
Old Jul 4, 2009 | 12:45 AM
HCR13's Avatar
Car: 1987 Trans Am
haha, been there, done that...just be lucky the oil cap didn't fall off in the road a few hundred miles back!
Old Jul 4, 2009 | 02:36 AM
1986iroc350's Avatar
Car: 1986 Iroc z
Engine: 350 tpi
Ya lucky you didnt have oil ALL OVER the motor from it spewwing out. A little simple green or some kind of degreaser should take care of the cleanup. Probably should do an oil change to get the contaminates out. good luck!!
Old Jul 4, 2009 | 02:38 AM
Car: 1986 Iroc z
Engine: 350 tpi
Come on now!! a third gen makin it 600 miles? have some faith there brother!! LOL
Old Jul 8, 2009 | 11:37 PM
Car: 90 formula
Transmission: auto
yeah i still have the old shitty cap just in case of something like this.
yeah i am surprised to but i have a warped intake that leaks anyways so im not to worried about how oily it is but spray if off from time to time.
Old Jul 8, 2009 | 11:39 PM
Car: 90 formula
Transmission: auto
lol ive been thru alot with this car as far as parts failure. mostly this fuel pump problem. keep getting a ton of crap ones. thats my biggest worry but other then that id drive it anywhere i needed.
ive replaced so many parts on this car i can tell you that i havent replaced lol
Old Jul 9, 2009 | 12:00 AM
HCR13's Avatar
Car: 1987 Trans Am
I've done the same with my car. When I go on long trips, I usually have a "road side mechanic emergency bag" which consists of several small sensors that can easily go bad on a trip...like TPS, IAC, a stock blaster coil, a few sparkplug wires (incase some go bad/get ruined) and a few sparkplugs, oil, coolant, a few vacuum lines, some wire, a list of OBD1 codes, and of course, the infamous ignition module... this is all along tire changing stuff... I think when I get some time, I'm going to swap the hardlines for braided AN lines and start carrying an oem spec fuel pump incase the walbro dies away from home...
Old Jul 10, 2009 | 11:38 AM
Car: 90 formula
Transmission: auto
yeah i used todo that. not a bad idea. what i do now is couple quarts of oil, tranny fluid and two jugs of coolant. which all have came in handy.
maroe624
Apr 16, 2017 08:29 AM
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
