Lt4 and tpi parts interchange?
Old Jul 7, 2009 | 09:56 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Ok, so last night I was at a car show talking to the owner of a tpi vette. He has the usual bolt ons and such but then he mentioned that his engine builder did all kinds of little tweaks here and there to get more power. The one thing that caught my attention is that he said that his motor had an LT4 knock sensor in it. I didn't ask about details but it sounded strange.
Do LT4 knock sensors fit our tpi engines? What would this do to performance, maybe more ignition advance for those with noisy valvetrain? Does anyone know about this?
Old Jul 7, 2009 | 05:34 PM
all4u's Avatar
Car: Firechicken
Re: Lt4 and tpi parts interchange?
I still need help with this. I have been searching all day and haven't found much yet. Can someone shed light on this?
Old Aug 10, 2009 | 07:10 PM
Mtrhd329's Avatar
Search corvette forum about this i remember reading about this when i was working on my C4. Something about better knock sensing.
Old Aug 10, 2009 | 08:04 PM
all4u's Avatar
Car: Firechicken
yeah I'll do that but I've been told that the best thing to do for my application is get a knock sensor from 86 or older because it is less sensitive. That might be something to look into.
Old Aug 10, 2009 | 08:48 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
IIRC, the LT1 and LT4 used the same knock sensor but a different knock module. The LT4 module was less sensitive that the LT1 unit to help the ECM fliter out some of the noise from the roller rockers the LT4 came with. The module is only for OBDII cars though IIRC, so it won't do anything in an OBD1 car because they never had the module to begin with - the signal from the sensor just went straight to the ECM. It won't work on a TPI motor.
Jake_92RS
Jan 28, 2020 10:37 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
