HELP My 90 Iroc Wont Start
Old Aug 4, 2009 | 06:59 PM
Matemk's Avatar
90 Camaro Iroc-Z 350 TPI
When i bought the car it had been sitting for 4+ years and never started, i couldnt hear the fuel pump turn on when i put the key in the ON position so i replaced the Fuel Pump, tank, Sending Unit, and Filter. Problem Fixed, Pump Primes when key is in ON position, and primes again after trying to start it.
I dont know how much pressure is at the fuel rail, but if i depress the schrader valve it sprays out with a decent amount of pressure.
I have 12v at each injector, but i dont have a noid light or test light to check for pulse, only have a basic DVOM, any way i can check pulse with it?
I can spray starting fluid down the throttle body and it will run for a second but then dies from lack of gas.
Trying to figure out if my problem is in the Ignition Control Module, ECM, Clogged Injectors or elsewhere.
Let me know what you think, and any other tests i can run without buying and replacing parts as an attempt to diagnose the problem.
Old Aug 4, 2009 | 07:10 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Re: HELP My 90 Iroc Wont Start
get a fuel pressure gauge and check that. try doing a search for the right PSI. did u check the resistance of the injectors to make sure they are all good?
Old Aug 4, 2009 | 08:24 PM
Matemk's Avatar
injectors had 17-17.2 ohms, noid light confirmed injectors pulsating.
will check fuel pressure at a later date
could it be the timing way off?
Old Aug 5, 2009 | 06:15 PM
Matemk's Avatar
Fuel Pressure at rail after prime is 43
Injector Resistance is 17 ohms
Injectors are pulsing, confirmed with a noid light and they have a constant 12v at each one
engine turns over
spray starting fluid into the throttle body and it starts up for a second or two
what else could it be???
any help is greatly appreciated
Old Aug 5, 2009 | 07:48 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
unplug each injector one at a time. Try to start the car after each one. If it ever starts, the one that is unplugged is bad. Same thing happend to me and my 90 IROC.
Old Aug 5, 2009 | 08:35 PM
Matemk's Avatar
got it started, took a rod and tapped each injector a little bit, played with the timing some more, and could hear it getting fuel in 1 cylinder. played with it some more and it fired up eventually.
Now its running really rough, gotta buy a timing light and check actual timing, and possible run it long enough to get that old gas outta there.
will keep updated
Old Aug 5, 2009 | 08:45 PM
Krik's Avatar
Engine: 5.7 TPI
If you don't have a timin light, you can hook up a vacuum gauge up and adjust the timing by looking for maximum vacuum. I have not done this yet, i just read about it earlier this week so I cannot attest to how accurate it is but an engine is nothing more than an air pump. The more vacuum the better tuned it is.
Old Aug 5, 2009 | 09:18 PM
Matemk's Avatar
i will just buy a timing light, they are really cheap when you work at a parts store.
going to set timing correctly then run engine to normal temp to make sure all the old gas is out of the lines, then do a full tune up and go from there.
I will try pulling off 1 injector at a time, see if that helps it at all
Now time to figure out why my tach is pegged out to the right, why oil pressure is sitting at 60, why my car freaks out when i put it in drive(almost as if the engine is trying to jump out of the car).
ahh the joys of buying a 20 year old car that sat up for many years...so many problems at once but will be well worth it in the end
Old Aug 5, 2009 | 09:24 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Mate I am going thru same process only I cant work on it till weekends you sais you just bumped the injectors?
Old Aug 5, 2009 | 09:32 PM
Matemk's Avatar
dont know where i read or, or if i read it, or if i imagined it, but something or someone told me to tap on the injectors, like if there was some kinda deposits sitting in there, clogging them up. so i took a metal rod and tapped on them gently.
I honestly have no idea if that did anything or not, but when i went to crank it back up i could hear 1 cylinder getting fuel and spark, so i tapped them all again and sprayed deep creep down the throttle body and it started up and stayed running.
So either tapping the injectors did something, Deep Creep works Miracles, or the engine stopped being a ***** and started up
Old Aug 5, 2009 | 09:36 PM
Krik's Avatar
Engine: 5.7 TPI
Deep ceep is the best stuff for cleaning out the motor without taking it apart.
Old Aug 5, 2009 | 09:40 PM
Matemk's Avatar
Sea Foam = Liquid Gold
Deep Creep = Aerosol Version of Sea Foam
Old Aug 5, 2009 | 09:52 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks I will get some deep creep before I go to work on it never tryed any .But I have used sea foam My car cranking matches yours exactly.
Old Aug 5, 2009 | 09:55 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
My car cranking matches yours exactly even the 4 yrs. I will take this advice with me Deep Creep
Old Aug 5, 2009 | 10:04 PM
Matemk's Avatar
spray a good amount in there(about 5 seconds worth in each opening), let it sit a minute or two and crank it up, hope it works for you like it did for me.
If you have an O'Reilly Auto Parts close to you, pick it up there, its about $10 a can.
Old Aug 6, 2009 | 09:04 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
there should be an oil pressure sensor by the oil filter. if it doesn't sense oil pressure then the fuel pump stops. they are pretty cheap (about $14 bucks or so at o'reillys). it could be worth looking in to.
Old Aug 7, 2009 | 03:39 PM
Matemk's Avatar
just an update, i continued to tap on the injectors, and have used about 1/2 a can of Deep Creep in the Throttle Body with a can of SeaFoam in the gas, and it is running alot better at idle
Old Aug 8, 2009 | 08:44 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
I tryed the bumping still wont crank. So I pulled the injectors hope I can clean them myself they were varnished like **** so maybe that will work. I cant afford new ones right now.Cant afford to send these off to get cleaned either so maybe I can do it got no money but plenty of time.
Old Aug 9, 2009 | 11:45 AM
Krik's Avatar
Engine: 5.7 TPI
Sounds like a fun project to me. I would clean them with a soft brush and some deep creep. Get a 12v battery to bench test them as you go. Just let them pump some dc through them. That should get them clean.
Take your time, do it right, have fun!
Old Aug 9, 2009 | 06:35 PM
Matemk's Avatar
might let them soak in a tub of SeaFoam or something similar over night
BTW i found the #4 spark plug wire up against the exhaust manifold, burnt to a crisp, replaced it and boy does that motor sound good now.
Old Aug 9, 2009 | 07:34 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Its happened to the best of us.
Old Aug 10, 2009 | 09:35 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
I ended up soaking the injectors with kroil oil over nite Sat. Then soaked with deep creep Sun. Got all but 2 unstopped. Put the 12 volts and pumped carb cleaner thru them.So now might just have to replace 2 instead of 8.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 11, 2015 03:17 PM
