Crack on starter mounting pad
Old Jul 9, 2009 | 01:42 PM
drumminfoolz's Avatar
Car: 1985 Trans Am
Engine: 360
I'm not sure that the crack is the problem, but I attached a picture of a block to show what the crack looks like. It's not my block, but you can see where I drew the lines, that's where mine is cracked. The crack is only on the bottom face of the mounting pad and doesn't extend up the sides of the block. One thing I can't be sure of is if the crack flexes when starting.
I found a starter brace but I don't know how it bolts up to the block. If the crack needs to be welded then I can have that done, but it would be a lot easier to put the brace on. Thanks for any input.
Attached Thumbnails Crack on starter mounting pad-sbcstartermount.jpg   Crack on starter mounting pad-starterbrace.jpg
Old Jul 10, 2009 | 10:11 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Crack on starter mounting pad
that brace doesn't look like anything GM ever installed on any third gen, so you're on your own with that, but if you find an older GM starter brace and use it, it won't remedy the issue with the crack. Welding is a good option, but welding cast iron seldom turns out well. I've done it successfully, but I was reshaping intake ports in Vortec heads, not fixing any cracks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
z28_AJ
Aug 27, 2015 08:59 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
