Where does this engine connector go to?
Old Jul 11, 2009 | 07:46 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
I was doing some work on my 350 TPI engine the other day and noticed this loose connector (see pic). The connector is back behind the distributor near the passenger side. It looks like it has never been hooked up to anything with the amount of dirt and grime on it. Engine runs fine except for recent code 32. Does anybody know where it should connect too?
Old Jul 11, 2009 | 09:03 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Where does this engine connector go to?
Intake air temp sensor maybe? Goes on the bottom of the upper plenum if it is.
Old Jul 12, 2009 | 08:35 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Thanks for the reply. I did notice a sensor already screwed into bottom of the intake plenum near the distributor. Maybe I will take off some more parts to see where this connector wire goes to. Engine seems fine, just weird seeing a hanging plug.
Old Jul 12, 2009 | 10:28 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
it could be for the EGR switch that's bolted to the coil mount .
Old Jul 13, 2009 | 08:40 PM
xdevenx's Avatar
Car: '89 Formula
Engine: T.P.I. 305
Transmission: Borg Warner T-5
Axle/Gears: Borg Warner 9 bolt - 3.70 posi
That connector goes to the egr solenoid that is(or at least should be) mounted right underneath your coil. not incredibly important, mine wasn't hooked up untill recently. but if you're getting an egr code, that might be it. But that is definitely where it belongs.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
toronto formula
Nov 10, 2015 06:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
