car wont rev. over 4000 and power is cut in half outta no where.....help!!
Old Jul 13, 2009 | 04:21 PM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
okay so i have a 1988 camaro i-roc with a 305tpi. it runs a little hot sometimes (210) but ive had no real problems since i bought it about 2 years ago untill now. out of no where my ars power was cut in half and it wont rev. over 4000. it sounds like a different car too. its so weird. id hate to bring it to a mechanic cause i honestly think it might be something stupid like replacing the fuel filter. or maybe a new fuel pump? it feels like its gasping for air or gas but it idles fine and starts right up. it might have somthing to do with the computer chip or my timing is off. im really lost with this one guys so any suggestions would really help. thanks again.
Old Jul 13, 2009 | 04:42 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: car wont rev. over 4000 and power is cut in half outta no where.....help!!
Running at 210* is not a problem with our cars. They like to run around 220* normally. you prolly are running lean due to a clogged or weak fuel pump. Check fuel pressure or buy a A/F ratio gauge to see if it is running lean.
Old Jul 13, 2009 | 07:17 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I have heard of clogged converters doing things similar to this. As far as running a little hot, well akmusclecar is right. the fan will not come one until about 225. I put a 180 degree thermostat, and hooked a toggle switch to a ground wire to ground out the heat sensor... or is called something different...
Old Jul 14, 2009 | 08:13 PM
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
yea i had a meachanic look at it an he decided that it was the cat. converter, its literaly falling apart. if you put ur hand by the tail pipe and have someone rev it little peices of the cat. come out. its like big peices of sand er sumthing. so im getting a new cat. thanks anyways!
Old Jul 14, 2009 | 08:36 PM
I'd keep the old one lolol
Ghettobird52
Jul 5, 2024 11:18 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
