cruise control
Old Jul 20, 2009 | 06:59 AM
85t/alover's Avatar
Car: 1998 Camaro Z28
Transmission: 4L60E. Right now.
Axle/Gears: 10 bolt, Torsion diff, 3.73 gears.
cruise control
My 91 ws6 formula didn't come with cruise. Anyway to add it now?
Old Jul 20, 2009 | 05:14 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: cruise control
The factory unit consists of the vacuum throttle activator,
a control unit that gets input from the transmission signal
generator, a vacuum release brake switch, and the wires
that connect everything -- most of which are unfortunately
imbedded in the very large main dash harness. So to scavenge
one out of a used parts yard, would require some detailed
knowledge of what to look for, where to find it, & how to get
it out. If you factor in some time, including allowing for errors,
it might be more advisable to look for an aftermarket unit, with
all the components & instructions. Hope I didn't rain on your
parade to hard...
Old Jul 20, 2009 | 05:19 PM
LTPMarine's Avatar
Re: cruise control
I don't think u can add it now very easily.
Old Jul 20, 2009 | 05:59 PM
85t/alover's Avatar
Re: cruise control
wouldn't the wires still be there? i mean the vss is still on the car regardless whether the car came with or without cruise.
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
