why why why???
Old Jul 29, 2009 | 04:35 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
why why why???
i just put a new engine in my 87 transam. everything is running fine but for some reason i still have that annoying ticking when ever i go up a hill or if i go above 2500 rpms. i've timed it as best as i can but my question is could low oil cause the ticking or is it just going to be a timing thing? if its just a timing thing maybe i'll go get it tuned once i get 500 miles on it and can take it to a dyno shop
Old Jul 29, 2009 | 08:46 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: why why why???
It could be a cracked flex plate. Did you put the old one on the new engine?
Old Jul 29, 2009 | 08:57 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: why why why???
no its a new flex plate. im thinking not enough oil in it or timing but it cant be that far off. i just cant seem to nail it
Old Jul 29, 2009 | 09:57 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: why why why???
pull your valve covers and check for lo0ose rockers, adjust lash accordingly
Old Jul 31, 2009 | 10:07 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: why why why???
right so i went ahead and adjusted my valve lash. let me make sure i did this right. turn crank to tdc on the compression stroke both #1 int and exh valves should be closed. adjust the following valves Exhaust 1, 3, 4, 8, Intake 1, 2, 5, 7. turn crank 180 degrees to put valves in position #6 with #6 int and exh valves closed adjust the following valves Exhaust 2, 5, 6, 7, Intake 3, 4, 6, 8. so this is what i did i loosened them till i had some play them i tightened them little at a time till there was no play and went 1/2 turn more. but now for some reason i dont get compression on my engine. i tryed to start it after i was done cause i figured it that it wouldnt mess with the timing and i got a huge backfire out of the carb.
Old Jul 31, 2009 | 11:16 PM
Chevy8588's Avatar
Re: why why why???
i would say that one or more of your valves are open allowing compression to leak past, when you have an engine that can run, its best to adjust the lash while its running
Old Aug 1, 2009 | 12:21 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: why why why???
and i do that by backing off one valve at a time until i here a ticking then i tighten until it goes away right?
Old Aug 1, 2009 | 01:25 AM
Chevy8588's Avatar
Re: why why why???
yes, be prepared to catch some oil though :P
Old Aug 1, 2009 | 09:06 AM
jv9999's Avatar
Engine: 5.7L/350
Re: why why why???
I would loosen them all a few turns until it runs. Then do them one at time while running. Loosen one until it clicks and then tighten it 1/4 of a turn at time until it stops, then 1/4 turn more.
Old Aug 1, 2009 | 09:29 AM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: why why why???
That backfire thing happened to me.
The fact is that when you go through the lash cycle....the first 1 you did will be loose again. I made the mistake of doing it all again...so when I cranked it up I had fire coming up through the carb. Very cool looking but freak out material and obviously not right.
I went ahead and loosened every single rocker til all were flopping.
Went out next day and lashed using OPPOSITES and all worked fine.
I understand that the system you used works fine...but it did not for me.
Also sadly I had deeper issues with the motor and it had to be pulled and rebuilt.
That's done now and it's running but I'm out of project money for the time being.
Old Aug 1, 2009 | 03:11 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: why why why???
HOORAY! i just reset all the valves and took her out for a spin. had to adjust the timing on the dist a bit but other then that it works and works like my dream (kind of). and i know what you mean by project money my next step is a paint job. im too embarrassed to put a pic of my car up cause it needs one bad. after that its on to restoration of the interior.
Old Aug 1, 2009 | 03:37 PM
Chevy8588's Avatar
Re: why why why???
no more ticking?
Old Aug 1, 2009 | 04:11 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: why why why???
no more ticking.
Old Aug 1, 2009 | 04:24 PM
Chevy8588's Avatar
Re: why why why???
good to see i was of some help to yah :P my 305 did the same exact thing lol
Old Aug 1, 2009 | 08:10 PM
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: why why why???
Great news.
Kudos to the home mechanic.
I'd hate to see a mechanic bill for the stuff we do on our own eh?
Nice work on getting it right...
Old Aug 1, 2009 | 08:22 PM
Chevy8588's Avatar
Re: why why why???
I worked for a dealership and i saw some of those bills, ouch...
Old Aug 2, 2009 | 12:28 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: why why why???
hell yeah. i couldnt imagine how much it would have cost to put my engine in. or how much it would have cost to readjust my valve lash. my wife wouldnt have let me do either and my car would still be sitting at my friends house engineless collecting rust
Old Aug 2, 2009 | 12:39 AM
Chevy8588's Avatar
Re: why why why???
through a dealer to do a long block you typically pay about 2500, - the cost of parts. i do engine swaps on the side for a grand. and i get it done quicker than the dealer does
