pretty sure i tried it all what else can i do?
Old Aug 4, 2009 | 08:12 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
ok so my valves have been lashed correctly i tried a distributor advance kit. i tryied timing it all over the place. so in the attached file you can here the noise my engine is making. im driving uphill going about 25mph and im not hitting the gas hard just moderate. any suggestions on why my engine is making this noise you can clearly hear. you can also see that the rpms dont go above 2k and stay around there. and you can tell when i ease off the gas and push the pedal back down.
File Type: mp3
Old Aug 5, 2009 | 01:09 AM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Re: pretty sure i tried it all what else can i do?
no one has any ideas?
Old Aug 5, 2009 | 11:43 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Sounds like an exhaust leak in the audio file, but a cracked flex plate is pretty common and will drive you crazy.
Old Aug 5, 2009 | 12:51 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
exhaust leak you say. alright i'll get under there today after it cools down and check it out. thanks. if that doesnt work i guess i'll try higher octane fuel
Old Aug 5, 2009 | 07:38 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
well i checked for loose bolts on the header and i was able to turn 5 of them by hand. so i tightened them down and low and behold. no more noise. ever seen that commercial that states when your car is running well you can feel it. yeah i can feel it
Old Aug 5, 2009 | 07:57 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
that's a very common problem. easy fix.
Old Aug 5, 2009 | 08:51 PM
jv9999's Avatar
Engine: 5.7L/350
Glad you found it and it was a simple fix.
Galaxie500XL
Feb 1, 2020 04:53 AM
Elephantismo
Feb 13, 2019 12:51 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
ramicio
Sep 28, 2015 01:18 PM
