Pushrod Question!!??
Old Aug 4, 2009 | 10:31 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
i have a 1990 Rs with a L03 Tbi, i am putting in a cam and lifters, i have roller lifters now and am putting regular lifters in with the new cam, the only problem is that my stock lifters are longer than the new ones so my concern is the pushrods not being long enough, to solve the problem I should just put longer pushrods in right?? Does anyone know what vehicle to get the pushrods for please let me know
Old Aug 5, 2009 | 12:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
My first recommendation would be to send the cam and lifters you bought back. It is a downgrade to go from roller to flat tappet lifters.
Get a similar OEM-style roller lifter cam. You can reuse your lifters and pushrods. It's a better set-up. The cam might cost a little more, but you won't need new lifters or pushrods.
Or, keep your downgrade cam and get pushrods for '86-earlier SBC. '87-'95 trucks also used the longer pushrods, because they had flat tappet cams.
Old Aug 5, 2009 | 05:17 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
Re: Pushrod Question!!??
Thank you very much for your response can you tell me what size a the 86 and earlier pushrods are beacuse on summit they have many different sizes of pushrod
Old Aug 5, 2009 | 08:05 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
stock length are 7.800 and 5/16" diameter.
beastin91rs
Oct 9, 2015 07:38 AM
gixxer92
Sep 1, 2015 04:32 PM
Thaney9
Aug 29, 2015 03:16 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
