what do you think of this build
Old Aug 7, 2009 | 08:19 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
here are some parts that i was thinking about putting together in the future. please add and subtract but keep it contructive. basic use will be street/strip and aggressiveness. of course this would be a project for me and my son to build when he's old enough. (about to be born on the 25th too)
Edelbrock 5001 - Edelbrock Torker II Intake Manifolds
Part Number: EDL-5001
Eagle Specialty Products B12109060 - Eagle Competition Rotating Assemblies
Part Number: ESP-B12109060
Crane Cams 10751-16 - Crane Gold Race Extruded Rocker Arms
Part Number: CRN-10751-16
GM Performance 88962516 - GM Performance 383 C.I.D. Engine Blocks
Part Number: NAL-88962516
Holley 0-80508S - Holley Model 4160 Adjustable Float Carburetors
Part Number: HLY-0-80508S
COMP Cams K12-602-8 - COMP Cams Thumpr Hydraulic Roller Cam and Lifter Kits
Part Number: CCA-K12-602-8
Airflow Research 1040 - AFR 195cc SBC Eliminator Street Heads
Part Number: AFR-1040
i calculate a c/r of 12.9:1 i think the calculator i used wasnt that in depth
Old Aug 7, 2009 | 09:30 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: what do you think of this build
According to Joe Sherman the Edelbrock Torker designed intake manifolds are among the worst products Edelbrock has put out.
Old Aug 7, 2009 | 10:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
with that compression, aren't you going to need airplane fuel? Hope this sin't going to be a daily (or even weekend) driver with the price of gas!
Old Aug 7, 2009 | 10:30 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
what intake would you suggest
Old Aug 7, 2009 | 10:38 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Performer RPM Air Gap!! If you have hood clearence just my 2 cents
Old Aug 7, 2009 | 10:42 PM
Car: 1992 RS
Engine: Carbed 350
Performer RPM or RPM Air Gap - most on here rave about either, and they have the same height (ie hood clearance). I happen to have the RPM - it's what was on my motor when I bought it.
Old Aug 7, 2009 | 10:51 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
O sorry almost knew what i was talking about, no hood clearence issues!
Old Aug 7, 2009 | 11:01 PM
Car: 1989 GTA
Engine: 369 TPI
I agree with the above posters. One you need to seriously reconsider that compression ratio for a street car. Two the Edelbrock RPM Airgap is a good intake manifold.
Old Aug 7, 2009 | 11:14 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
i think im going to switch to these heads
Brodix 1028100 - Brodix CNC-Ported Wild Thing KC IK 210 Cylinder Heads for Small Block Chevy Part Number: BRO-1028100
so what would be a good c/r my choices are 11.8:1, 10.3:1, 9.2:1, 9.6:1, 10:1, 9:1, 8.3:1, 10.2:1 for 76cc chamber
or with the heads i had on the c/r choices would be 11.6:1, 10.3:1, 10.7:1, 11.4:1, 10:1, 9.1:1, 11.6:1, 13.7:1 for 65cc chamber
thats with piston dish/dome +5, +16, +12, +7, +18, +28, +5.4, -7 consecutively on both
airgap its gonna be i was worried that it wouldnt clear
Old Aug 8, 2009 | 12:02 AM
quick90rs's Avatar
Car: 1990 Camaro RS
Axle/Gears: Posi
10:1 or 9.6:1 are good on street cars
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
