Alternator down in DK...
Old Aug 10, 2009 | 07:01 AM
kemo's Avatar
Hi all..
Having som problems over and over again with ac-delco CS 130..
Have 2 working alternators now , but no charge When installed in the car ? GM CS connector 4 pin S,F,L,P. Ign.+ , and constant +, is present.
Have drawings of 84 camaro, but is not simu. to this..
Anyone ???
Old Aug 10, 2009 | 07:38 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Alternator down in DK...
i assume you have a 3rd. gen. car . check all your fuseable links . large red wire from alt. , & ones going to small terminal near battery . if you find a soft spot in the wire theres your problem . can be repaired like any other broken wire . good luck .
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
