Smog pump and Heater delete
Old Aug 18, 2009 | 10:18 AM
Firebird Mess85's Avatar
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
In order to get rid of the smog pump and replace it with a pulley what am I looking for because all I'm finding are A/C delete pulleys. I did find one smog delete pulley but it was for a serpentine setup which I don't have.
Also, my car's A/C setup is removed except for the chrome thing by the heater core. I also bypassed the heater core. I need more room to work on the engine. What do I need to do to remove the chrome thing and the big piece sticking out by the heater core?
http://i45.photobucket.com/albums/f6...4/000_0129.jpg
Old Aug 18, 2009 | 12:02 PM
taonindo's Avatar
Car: 82 firebird
Engine: 406
Re: Smog pump and Heater delete
cant you just go to differant belts. i dont have ac or a smog pump, just running nonstock belts
Old Aug 18, 2009 | 12:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you don't have a serpentine set-up, all you need to do is remove the A.I.R. belt to make it illegal.
What "chrome thing" are you talking about?
Old Aug 18, 2009 | 01:27 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
I think the chrome piece is the aluminum tube AC piece going into blower box....I don't know exact part terms that well...but like the reciever/drier or evaporator....
Old Aug 18, 2009 | 01:30 PM
That's correct.
I realize I could remove the pump and belt but I thought I read somewhere that it wasn't recomended.
Old Aug 18, 2009 | 01:33 PM
Engine: L98 494hp
it should pretty much just unbolt....the hard line, same thing, loosen and remove....the AC is still not pressurized I'd hope....
Old Aug 18, 2009 | 01:43 PM
five7kid's Avatar
You can remove the entire AC system by removing the top of HVAC box and the radiator, and lifting the entire system out (after unbolting the compressor from the engine, of course) in one piece without breaking any of the lines. The receiver/drier on the front of the HVAC box will come with it (it's aluminum, not chrome).
Removing the A.I.R. isn't recommended because it's required by Federal law.
Old Aug 18, 2009 | 01:56 PM
I understand it's required.
Is there a different heater box attached to the firewall for non A/C vehicles. I already took out the A/C. I just have that aluminum thing attachend and wasn't sure if it was fine to remove it and the big heater box attached to the firewall.
Old Aug 18, 2009 | 02:30 PM
five7kid's Avatar
It's called an "AC delete" heater box. Uses a different fan than AC, but otherwise bolts to the firewall.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
lakeffect2
Aug 23, 2015 08:44 AM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
