non baffled valve covers and pcv
Old Aug 20, 2009 | 12:09 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I am getting oil all over my plugs
I have old school m/t valve covers that do not have baffles
would the pcv valve suck up enough oil to leave deposits on my plugs
thanks
Old Aug 20, 2009 | 01:13 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: non baffled valve covers and pcv
PCV shouldn't be causing the plug problem; I'd be more prone to say its a valve stem seal issue. Have they ever been replaced?
Old Aug 20, 2009 | 02:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You can suck quite a bit of oil through the PCV valve. If there is enough to leave deposits on your plugs, you should see oil in your intake manifold.
Old Aug 20, 2009 | 02:38 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
I was a bit too quick to the response button; five7 does bring up a good point. If the oil is being sucked through the PCV, you should definitely see oil in the intake manifold.
Old Aug 20, 2009 | 06:32 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yes, but where does the PCV suction deposit the engine gasses? Is it back by cylinders 5 & 7 or does it get distributed evenly?
I would think that the breather would be more likely. Getting sucked into the TB would have a much more even spread throughout the engine.
On the other hand, maybe a rebuild is in order.
Old Aug 20, 2009 | 07:51 PM
jamon8's Avatar
Engine: 350 tpi
its a pretty fresh rebuild and I had baffeled valve covers on the motor to begin with and the plugs stayed nice and dry
how does the pcv valve distribute the gasses
Old Aug 21, 2009 | 01:36 AM
five7kid's Avatar
What induction do you have, TPI?
It's typically routed to the intake manifold under/behind the throttle blades. Gets distributed evenly to all cylinders that way.
Old Aug 21, 2009 | 10:50 AM
jamon8's Avatar
Engine: 350 tpi
it is tpi off a 89 formula maf
Old Aug 21, 2009 | 04:38 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The TPI's get the breather going to below and behind the TB blades in the plenum. The PCV goes to the manifold.
How does the PCV system get distributed? It goes directly to the intake manifold.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
