Seafoam HELP
Old Aug 22, 2009 | 11:53 PM
Njs305t/a's Avatar
Car: 1987 Trans Am
Axle/Gears: 2.73 posi
Seafoam HELP
I have been hearing a lot about seafoam lately but I don't know much about it. What does it do for the motor? Where do you put it? Where can you buy it?
Your help is greatly appreciated.
Thanks,
Nick
Old Aug 23, 2009 | 01:28 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Seafoam HELP
seafoam, the ultimate smoke screen. its like hella smoke its awesome never done it, but ive seen videos, you suck it in the engine through the brake booster vacuum line.
http://www.youtube.com/watch?v=s6F406Z6Vns
http://www.youtube.com/watch?v=X832d4MtYUc
Old Aug 23, 2009 | 02:33 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Seafoam HELP
all seafoam really is, is a solvent that is safe for seals... sorta... can be added to any fluid in the car except coolant and then drained shortly after... its affects on a WELL MAINTAINED vehicle are negligible...
adding seafoam can cause oil leaks...
Old Aug 23, 2009 | 12:30 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: Seafoam HELP
I just poured half of it straight down the throat of the carb. Then I hooked it up to a vacuum line on the carb and used the other half. Right before the can was empty, I let the motor stall out while sucking up the Seafoam, that way it could sit in the intake, on the valves and pistons and really dissolve the gunk. Let it sit for a half hour or so then started it up...with a lot of smoke lol. It smoked lightly for about 30 mins after, but it stopped after driving around for a bit and getting everything up to temp. No issues, motor ran better all around after.
I wouldn't recommend putting it in the gas tank or oil...I've never done it and everyone I've talked to agrees. In my opinion, it works best the way I used it.
Old Aug 23, 2009 | 03:49 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Seafoam HELP
It makes a lot of smoke because it's mostly oil (along with alcohol and naphtha).
Old Aug 23, 2009 | 08:34 PM
Njs305t/a's Avatar
Car: 1987 Trans Am
Re: Seafoam HELP
Thanks guys.
Old Aug 24, 2009 | 06:43 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: Seafoam HELP
if you put it in a clean motor it doesn't smoke at all...
the description a couple posts above is the best 1. it works wonders on an aged motor thats never seen a upper intake cleaner.
Old Aug 28, 2009 | 12:56 AM
Richwiz1's Avatar
Re: Seafoam HELP
I have used in my bike it ruined the carb my brother used it and ruined his fuel pump. If you really want it autozone or other parts place carries it.
Old Aug 29, 2009 | 06:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Seafoam HELP
I just used it. Didn't get much smoke.
2 weeks later I ran a compression test and found that I had a bad cylinder. Pulled the head and found that the seafoam didn't do a friggin thing. This was on a project car that I had and it had not been maintained very well.
Old Aug 29, 2009 | 06:43 AM
EvilCartman's Avatar
Car: '82 Z28
Re: Seafoam HELP
Another good cleaner, which of course you can't get here in CA anymore, was GM top engine cleaner.
Old Aug 29, 2009 | 06:51 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Seafoam HELP
Now THAT was some good stuff. I was able to get some here in Illinois 2 years ago.
Old Aug 29, 2009 | 07:20 AM
Car: 91 RS
Engine: 350 vortec
Re: Seafoam HELP
also there is this fancy stuff called water... comes out of many taps across the US and canada...
while it wont clean the throttle body well it will clean the cylinders extremely well
DIRECTIONS: start engine let it warm up remove anything before the throttle body then mist the water in large quantitys through the blades dont stall the engine here but give it enough to make the engine complain about it...
Old Aug 29, 2009 | 08:49 AM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Re: Seafoam HELP
Evil, I'm in SO CAL they got it at Walmart. Later.
Old Aug 29, 2009 | 09:39 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: Seafoam HELP
i have used that for decades. all that super heated steam just breaks up anything not part of the engine. it will be clean after than.
gta892000
Aug 11, 2019 11:16 AM
86White_T/A305
Mar 6, 2016 01:48 PM
HoosierinWA
Oct 7, 2015 10:15 AM
rjcme
Sep 5, 2015 01:23 PM
bakerstreet
May 29, 2007 09:56 PM
