350 4bbl - Engine Bay 'Clicking' Noise
Car: 1986 Pontiac Firebird Trans Am
Engine: 350 4bbl
Transmission: Stock Auto
Axle/Gears: Stock
Hey guys,
I drive an 86 Trans Am. I swapped the 305 for a 350 4bbl that I pulled from an 86 Blazer. I did not rebuild the engine because, despite the fact that it had not run in years, it started immediately at the turn of the key.
Recently, I heard a tick coming from the engine. Or perhaps a click, i dunno really.
I've dealt with exhaust leaks coming from the manifold, and they get louder as I accelerate and the engine runs at a higher RPM. This doesn't. This stays loud enough to be heard just barely over the radio and exhaust and is extremely irritating.
I took a look under the hood and noticed my power steering belt was loose and beginning to turn itself over, so I put it off as being the belt clicking in some manner.
Then the belt shredded today. I lost power steering. And i was extremely, extremely, EXTREMELY disconcerted to hear the tick, going on and on.
I looked and looked and cannot find the source.
Please tell me it's not a valve clicking, and give me some alternative to check. Or if it cannot be anything but a valve, give it to me straight.
Thanks guys
Thanks guys
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 350 4bbl - Engine Bay 'Clicking' Noise
You can tell if it's valvetrain or bottom end by how fast it clicks. Time the number of clicks you get in 10 seconds and multiply by 6. That's clicks per minute. Compare that to RPMs and it will either be going half the engine's speed (valve train), or clicking once per revolution of the rotating assembly (bottom end).
Engine: 350 4bbl
Axle/Gears: Stock
today i took a video of the engine clicking
take a look and tell me what you think
thanks
http://www.youtube.com/watch?v=DKLzW7l2SlA
thanks
Car: 86 Trans Am
Engine: 383
Transmission: Probuilt 700r4
Axle/Gears: 2.77 BW 9 Bolt
does the clicking get faster as you rev the engine?
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Sounds like a sticky lifter//valve or an exhaust leak in. A hole//crack anywhere on the drivers side exhaust manifold? All bolts tight?
That's about all I know to check.Good luck & post up when you find out!!??
Engine: 350 4bbl
Axle/Gears: Stock
to answer your questions:
yes, the clicking gets faster when i accelerate, but not louder like an exhaust leak
i just repaired an exhaust leak less than a month ago and replaced both gaskets and bolts. with the exhaust leak, it got louder and faster as i revved. this just runs faster.
how would i go about fixing a sticky lifter/valve?
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
drop in some lucas oil treatment ... whatever the bottle reccomends... Its usually allows better lubrication. I did have an old 82 that had the pretty much same set up... It sounds like one of three things... sticky valve (lucas might help) , lifter ( again lucas oil treatment), or an exhaust leak... when you changed out the exhaust manifold gaskets did you heat up the motor to temp and retorque the bolts?... Another thing to look into is headers with dead soft aluminum crush gaskets... thats all I use now and the seal perfect the first time everytime and don't leak period...
Car: 91 Z28
Engine: aluminum block 5.3
Axle/Gears: 4th gen rear 4:10 welded
by the video it kind of sounds like a spark plug wire arcing. it also sounds like it misses a little too. you can let the engine run in the in the pitch dark and look for a spark plug wire shorting to ground
AkDrifted
Aug 17, 2015 07:45 PM
